Bizhub c224 black dev eating
  • pern2808
    • Sep 2015
    • 17
    Hi all, scratching my head on this one. Have a C224e which has been eating dev over the last 6 weeks. Have replaced both drum and dev unit. Genuine parts and genuine toner being used. No error codes. Have replaced HV board also. Runs fine for about 5 days then dev is depleted. Have run stabilisation and get a weird pattern on the black test scan patter. Printing is fine though until dev runs down. Any ideas as on 2nd dev unit now and customer has called agin today saying the low dev pattern is appearing again on prints/ copies. Machine has been cleaned, checked contacts. Has had a new transfer belt recently but hasnt coincided withdev depletion. Help!! Thanks in advance.
  • Synthohol
    Certified Konica Expert
    • 5927
    Re: Bizhub c224 black dev eating
    have a look at these.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4792
      If any of the Dev and/or drums are over life you will have to replace them. "Any" dev unit can dump if one of the other drum or dev units are over life.
      • jamesyboy
        toner monkey
        • Jul 2010
        • 188
        erase lamps would pull dev if faulty
        • G6token
          • Feb 2018
          • 19
          • Synthohol
            • 5927
            keep in mind, if you dont use OEM toner you are also killing the units.
            but check the bushings in the ENG document
