c6500
  • afterhours
    • Mar 2017
    • 152
    c6500
    Hello everyone.
    I was wonering if anyone knows a way to turn off malfunctions on a c6500. I realize that this is a huge no no but I need it to bail out a customer for 2 days till he gets his parts. I remember reading on here that someone had done this as a temporary fix but I read that a while ago and did not take note of it. Please help if possible.
    Thank you in advanced
    Im a Loser Baby!!!
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: c6500
    please be 100% specific.
    different malfunctions are reset in different ways.
    • afterhours
      • Mar 2017
      • 152
      Re: c6500
      I apologize. Here are the details.
      C-2861 Gamma correction/Y aborted.
      Patch output voltage is high.
      (Error 3
      Im a Loser Baby!!!
      • Synthohol
        • 5799
        Re: c6500
        Problem
        C-280x, C-285x, C-286x or C-287x error codes.
        • C-2801 (Yellow)
        • C-2802 (Magenta)
        • C-2803 (Cyan)
        • C-2804 (Black)
        • C-2851 (Yellow)
        • C-2852 (Magenta)
        • C-2853 (Cyan)
        • C-2861 (Yellow)
        • C-2862 (Magenta)
        • C-2863 (Cyan)
        • C-2871 (Yellow)
        • C-2872 (Magenta)
        • C-2873 (Cyan)
        Solution
        CAUSE: Gamma correction abnormality caused by poor patch creation on the image transfer belt.
        SOLUTION: Check output test patterns for each color. Ensure that each color station is producing a good quality pattern free or bands, void lines, blotchiness or other abnormalities.
        if the belt has no issues then vacuum all the misted toner in the entire process carriage and see if that helps
