Bizhub 363 DF 621 jams 2 sided originals
  • tsbservice
    Field tech
    • 7992
    Hi Guys,
    I have dealing with J66-01, this is for ADF turnover section.
    This occurs only on 2-sided copy/scan job. It always jams every single original like:
    -original exits completely, without trying to reverse
    -original jams on switchback when two rubber rollers(exit rollers) try to reverse it back
    -original manage to reverse once but failed on the second pass(this is rare case)
    New set of pick/feed/sep rollers are installed, all transport rollers(plastic and rubber are cleaned).
    I read about updated parts which fight problems with originals feeding, maybe scan motor adjustment.
    I had worked many years with Toshibas, now that KM staff is new for me(don't have access to more than SM, Parts list), so treat me gentle like a newbee
    I plan to take this DF with me to test it on another machine and eventually swap parts.
    Any thoughts and ideas would be greatly appreciated.
    TIA
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: Bizhub 363 DF 621 jams 2 sided originals
    I would be looking at the actuator/photocell for the turnover section. change the photocell after checking fo a sticking actuator, then maybe swap boards.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      This is the board I mentioned,, A143 PP7Y 00 PW Board Assy
      This is the only photocell used in that doc feeder. A143 PP48 00 Photointerrupter
      • tsbservice
        Field tech
        • 7992
        That one was real lemon. Whe swapped all parts that are supposed to do with these from working DF-621, and still no luck. I have to replace whole DF with another one as clients urged to scan big piles of docs.
        Anyway, thanks for suggestions fixthecopier.
