C203 Lost network
  • mrfuser
    • 1617
    C203 Lost network
    Re: C203 Lost network
    reload firmware time
    • mrfuser
      • 1617
      • copyman
        Owner / Technician
        • Sep 2005
        • 4711
        Sounds like that should be the fix. If you end up needing the MFP pwb let me know.
        • Synthohol
          Certified Konica Expert
          • 5838
          have you tried using the IP listed in system information in the utility menu?
          or print a config page to see what IP it thinks it is?
          match the copiers IP scheme on your laptop and try a browser.
          i would back the machine up to a USB, initialize the network, import the backup and try setting the IP again.
          • mrfuser
            • 1617
            • Synthohol
              • 5838
              that sucks.
              • rrrohan
                • Sep 2011
                • 1977
                So arp allows you to change IP of copier without needing to log in? That sounds like it could be used maliciously if so
                • mrfuser
                  • 1617
                    • 14756
                    Problem
                    Network menu button is missing from Admin Mode.
                    Solution
                    CAUSE: Corrupt NVRAM and/or failed PWB-MFP.
                    SOLUTION: To correct:
                    1. Perform an "All Data Clear" under Service Mode g System 1 g Initialization.
                    2. If that does not work, perform the NVRAM Recovery Procedure (not available for all models).
                    Notes:
                    a. Before performing the NVRAM reset please perform a NIC RESET which is also located on the NVRAM reset firmware utility. This will likely solve the issue without having to completely initialize the machine. Please be sure to back up all network settings before performing this function. This only pertains to the models which have the NVRAM reset utility.
                    • bizhub C203/C253/C353/C353P
                    • bizhub C250/C250P/C252/C252P/C300/C352/C352P
                    • bizhub C451/C550/C650
                    • bizhub C351/C450/C450P
                    b. Please wait approximately 10 minutes for the tabs to appear. Be patient; DO NOT power cycle the machine as that only restarts the wait process.
                    3. If the NVRAM Recovery Procedure is unsuccessful, replace the PWB-MFP, PRCB on C300/352, (see part numbers below) and NVRAM.
                    Note: To receive a replacement NVRAM, please utilize the Online Technical & Special Program order form located within MyKonicaMinolta.com:
                    a. Login to MyKonicaMinolta.com.
                    b. Select the Service tab.
                    c. Select Warranty, Repair, & Special Programs (menu at left side of screen).
                    d. Click on Warranty Services & Technical/FOC Programs (in center of screen).
                    e. Select NVRAM/BRU Replacement Program.
                    f. Fill out the form.
                    IMPORTANT: All requests for NVRAMs must be approved by the SSD Contact Support Center and a problem ticket generated. If a request is received without an established problem ticket number the request will be denied.
                    Before replacing the NVRAM, thoroughly troubleshoot the problem. The NVRAM should be replaced only as the last resort. Many times replacing it DOES NOT solve the issue and, when it does, only a setting in the NVRAM may have caused the problem. Please refer to attached NVRAM Troubleshooting Guide for more detail.
                    • AjitN
                      • Mar 2009
                      • 287
                      Is it possible that some other device on the network have same IP address?
                      Remove network cable from machine and try rebooting machine to change IP
                      Hope this helps
