I have a KM Bizhub 223 that jams every time in the duplex vertical turnaround after the paper passes the upper sensor. I am not an experienced Konica Minolta Tech and would appreciate any assistance.
KM Bizhub 223, duplex jamming
Re: KM Bizhub 223, duplex jamming
Hello! I kind of have the same problem also. The jam code isCode:66-14
You're a little closer to fixing your machine since you have a jam code. The next step is to look up that jam code in the field service manual.
I don't know why I'm doing this ... ok, 66-14 jam involves PS4 document reading sensor and PS5 exit sensor. If you need help locating those sensors the diagram is on page 638 of that same field service manual.
You can also check the operation of those sensor in ADF Sensor Check described on page 543 of that same field service manual.
Wow! With all that useful information all in one document, maybe you'd like to look at that field service manual. Just a thought. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
It is untimely to mix questions in one common topic. Instead, try to post your own thread.
This will help greatly when other members search for problem like your with ADF.
Anyway, good person like blackcat already pointed your attention to the right direction.
Get that sevice manual and start reading.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
https://drive.google.com/file/d/1TSZ...ew?usp=sharing
may even be a broken or snagged gate the the rear of the paper catches on.
i saw the 2nd vid, maybe give the exit actuator spring another wrap.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
Finally got back to machine with duplex problem today. There was a piece of mylar that was interfering with paper as paper was exiting duplex turnaround. Thanks everyone for your input.Comment
the vid shows a physical issue, like a one way bushing is slipping on the front side when it retracts the paper and only thye rear rollers are spinning backwards.
I still don't know how it happened though since it's not possible to do adjustments in the guide. It only had 1 screw on the side.Comment
Perhaps the DF is not resting squarely on top of the MFP, and the exit ramp on the glass does not align with the exit ramp on the DF?
If it were me, I'd raise the DF just 25mm or so and shine my flashlight down the slit glass to see if they align, or more likely cross over each other. A good reference is just to stand back a little and observe weather the DF is about square on the top of the machine. =^..^=If you'd like a serious answer to your request:
