Bizhub C220 firmware update
  • Metasfrastiki
    • Mar 2022
    • 4
    #46
    Re: Bizhub C220 firmware update
    Hello,
    Can you please send me the firmware?
    How do you want to pay you?!
      • 8163
      #47
      Originally posted by Metasfrastiki
      Hello,
      Feel free to contact us further should you have any questions.
      Printer & Copier Firmware - www.printerfirmware.co.uk
      • Goatguy
        • Jan 2023
        • 1
        #48
        If anyone has the latest firmware for this unit could you please send it to my via PM?
        • Stevobaaba
          • Nov 2022
          • 1
          #49
          Originally posted by gideon
          Thank you very much, it is what I need.
          Hello, can you send the firmware you recieved to my pm. Thanks it's very urgent
          • rjjr148
            • Jan 2023
            • 8
            #50
            I want to buy konica minolta c220 special firmware for error clear 5501.
            Will the firmware you provide fix the error 5501.
            & please tell me firmware name
            Thanks in adavance
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5832
              #51
              how is firmware is involved?
              C5501(1) Contents
              Trouble type AC signal abnormality
              Trouble code C5501
              Rank C
              Detection timing Signal is not detected for a given period of interval when AC frequency is measured with the power switch ON or when fusing heater is turned ON/OFF.
              Trouble isolation -
              Relevant electrical parts • Fusing unit• DC power supply (DCPU)• Printer control board (PRCB)
              (2) Procedure
              Step Action Control signal Location of electrical components
              1 Check the fusing unit for correct installation (whether it is secured in position). - -
              2 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary - -
              3 Change fusing unit - -
              4 Change PRCB - -
              5 Change DCPU
              lol, they actually made a FW to ignore the signal or lack thereof.
              4.10 C5501SymptomC5501 (AC signal abnormality) is displayed.CausesIf the MFP is installed near noise generated by a private electric generator at a construction site etc., the error may be displayed.CountermeasuresIf the MFP is installed in an environment such as described above, and you would like C5501 to not be detected, install the following firmware. Firmware: Ver. A0ED0Y0-0050-G10-04• The improved program does not require [C5501] detection control to be run.NOTE• [C5501] is also unable to be detected due to causes other than the above environmental conditions. To enable [C5501] detectioncontrol, do not install the firmware
              since the fuser is involved id feel unsure about the safety now.
              id rather fix the fault that causes it. but thats me.
              • Synthohol
                • Mar 2016
                • 5832
                #52
                also as a matter of online courtesy, i will point out asking for the same firmware in 5 threads is overkill.
                us diehard members check in here daily sometimes multiple times and it just seems so "toddler tugging pants leg of everyone in crowd" to ask the same thing.
                also it "seems" that contributors get faster results than non sponsoring members. could just be a coincidence?
                my access to newest FW has been cut off so im speaking for any other member that may be compelled to help once you have a contributor badge.
                ive seen it happen dozens+ of times but no guarantee.
                  • 8163
                  #53
                  Thanks in adavance
                  We have received & replied to your multiple emails regarding this.
                  • SoulShine
                    • Nov 2023
                    • 1
                    #54
                    Hi all!
                    Have a c220 that started spouting out c-c170 error codes as it turns on and then cycles off and on to do the same thing. I'm hopeful that I can update/reflash the firmware for a fix. Does that sound correct?
                    Any insight or support would be appreciated!
                    Thank you in advance!
                    Matt
                    • Synthohol
                      • Mar 2016
                      • 5832
                      #55
                      not looking like FW but you can try i guess.
                      • Synthohol
                        • Mar 2016
                        • 5832
                        #56
                        • ejfel
                          • Oct 2023
                          • 2
                          #57
                          Hello everyone!
                          Is it possible to send the firmware? Thank you in advance! My email: mrkbgv@gmail.com
                            • 8163
                            #58
                            Originally posted by ejfel
                            Hello everyone!
                            Happy to help, drop us an email via either website below.
                            • AS1234
                              • Feb 2025
                              • 1
                              #59
                              I would be grateful if someone could provide me with the firmware files for the Minolta C220. Thank you in advance. Regards
                                • 8163
                                #60
                                Happy to help, drop us an email via website below.
