Bizhub C224e firmware
  • mayorg
    • Feb 2015
    • 53
    #46
    Re: Bizhub C224e firmware
    Thanks for
    The printer showing this error
    • tsbservice
      Field tech
      • 8007
      #47
      Originally posted by mayorg
      Thanks for
      Input serial number in CE mode -> System 1 -> Serial number
      • mayorg
        • Feb 2015
        • 53
        #48
        I was unable to enter the service mode
        • mayorg
          • Feb 2015
          • 53
          #49
          I have been trying to enter the service mode the machine is not responding
          • Synthohol
            Certified Konica Expert
            • 5822
            #50
            hold down panel reset while booting, that enters trouble reset mode and you can enter the SE password then and input the serial#
            • mayorg
              • Feb 2015
              • 53
              #51
              Please which one is the panel reset Botton?
              • mayorg
                • Feb 2015
                • 53
                #52
                I will be glad if you can show me how to reset it thank for the reply
                • mayorg
                  • Feb 2015
                  • 53
                  #53
                  And the machine showing C E301 Please any that have experience with this error code please kindly help out
                  • Synthohol
                    • 5822
                    #54
                    The yellow one that says Reset.
                    • mayorg
                      • Feb 2015
                      • 53
                      #55
                      Have done that still the same samthing
                      • mayorg
                        • Feb 2015
                        • 53
                        #56
                        I was unable to enter service mode
                        • Synthohol
                          • 5822
                          #57
                          Did you hit trouble reset and it said "ok" and then try 9272x4
                          • tsbservice
                            Field tech
                            • 8007
                            #58
                            No need to hit TR just go straight S 0 0 etc.
                            • copier tech
                              • 8142
                              #59
                              Please I also need the frameware for bizhub c 224e this is my email mayowaid@gmail.com
                              Happy to help, you can contact us at the links below.
                              • Mukanya
                                • Sep 2019
                                • 1
                                #60
                                Can you please assist with Bizhub C224e firmware
                                vallyventures@gmail.com
