C203 line issues
  • copyman
    Owner / Technician
    • Sep 2005
    • 4595
    Re: C203 line issues
    Good thought Hans. This may be the calm before the storm (gears chattering). If the trans belt cleaning unit was thoroughly vac'd out and put back into mach then you should be able to get several clean pages before lines would show up again? Another thought, if you go to vac out the trans belt cleaning unit and it's not packed with toner then does that mean the machines waste transport is working ok? I would think so.
    • jeffreyclay
      • Sep 2008
      • 43
      May be a longshot but reminds me of ripple in the power supply (open filter capacitor). It's hard to imagine that all 4 channels of the copier have identical failures. The final fix should be pose some interesting discussion.
      • t85ster
        • Mar 2015
        • 39
        Originally posted by paulrid
        Thanks for the reply blackcat,
        i have printed those those off but don't have them to attach but I could see the pattern for all colours, when I swapped IU's the pattern were identical. We may need to swap out machine but it's up a narrow staircase and I'm old with a bad back 😂
        Paul.
        Paul, I"m 64 with a bad back, I have to swap out a C754 w/Booklet Finisher & LCT up a narrow wooden staircase on Tuesday, can you give me an assist? Seriously, but lol.
        • paulrid
          • Nov 2011
          • 206
          #19
          Sorry all for not replying I've been side tracked for a few days 😂
          I havent been been back to this yet so I'll try a few more things and let you know, probably just swap it out.
          • paulrid
            • Nov 2011
            • 206
            #20
            by hand? That can't be done 😂 They weigh more than a small car lol
            I would have said im busy that day 😂😂 but as its now Tuesday how did it go?
            • t85ster
              • Mar 2015
              • 39
              #21
              Paul, it went really well, me watching the four big moving company dudes carrying it up strapped to a refrigerator dolly.
              It was well worth the $215.00 they charged!
              Tom
