Bizhub 283
  • liondor1969
    • Jun 2016
    • 72
    Bizhub 283
    Hallo
    i buy today a used bizhub 283..only black,is posible too use black color toner from c8000 to refil my bizhub 283 ? I have in studio a new Acurio Print C2060L..is posible to refil bizhub with black toner from my C2060L ?
  • Toxic
    • 697
    Re: Bizhub 283
    Not even close to match that but you can try,i am curious about results...
    • allan
      RTFM!!
      • 5462
      Re: Bizhub 283
      Do it just do it.
      Whatever
      • copier tech
        • 8144
        Re: Bizhub 283
        Yeah do it I dare you!
        Post a print sample after for us to laugh at!
          Re: Bizhub 283
          Originally posted by liondor1969
          Hallo i buy today a used bizhub 283..only black,is posible too use black color toner from c8000 to refil my bizhub 283 ? I have in studio a new Acurio Print C2060L..is posible to refil bizhub with black toner from my C2060L ?
          sure you can...
          how big is your checking account?
          you will be paying for new drums/devs/fusers.
          the toner formulas ARE NOT EVEN CLOSE!
          BUT IF YOU WANNA DO IT.... DO IT!
          • Synthohol
            Certified Konica Expert
            • 5824
            Re: Bizhub 283
            since we are on the subject, my car uses gas but the station around the corner sells diesel cheaper, thats the same right? i should have no problems substituting since fuel is fuel amiright? amiright?
            oy vey...
            • Downunder
              • Aug 2007
              • 174
              Re: Bizhub 283
              And after you have tried that, why don't you put diesel in your petrol car or vice versa...
              • allan
                RTFM!!
                • 5462
                Re: Bizhub 283
                No really it could work....
                The worst that can happen is a dev replacement.
                Would be nice and shiny prints.
                If it gets past the drum, the fuser temp should be dropped.
                Whatever
                • liondor1969
                  • Jun 2016
                  • 72
                  Re: Bizhub 283
                  I do not want to do experiments, I wonder if anyone has done this and if black toner is compatible at 6500 I reloaded toner from c8000 and I worked a few years with him without any problems.
                  Tx
                  • allan
                    RTFM!!
                    • 5462
                    Re: Bizhub 283
                    It would be experimental. We don't have the time or energy to play with this.
                    That is why we would like to know the outcome to this.
                    What i do know it that B250, B282 toner will work ok.
                    Whatever
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4689
                      Re: Bizhub 283
                      WHY? .............you can buy this toner so cheap. Aftermarket is like $10 !!!!
                      • 3ktlc
                        • Feb 2018
                        • 180
                        Re: Bizhub 283
                        Why take that chance? Could cost way more in the long run. Have found compatible toner that is acceptable for this machine.
                        • jeffreyclay
                          • Sep 2008
                          • 43
                          Re: Bizhub 283
                          Tx
                          Why would you even want to try this? Does customer have a closet full of other toner? Not worth the risk, just use the correct supplies!
