Bizhub C452 leading edge faded
  • Leyahné
    • Feb 2016
    • 44
    [CQ] Bizhub C452 leading edge faded
    Hi Guys I need some assistance with a C452 with a weird problem. The customer had a power failure after power was restored the machine had copy quality problems. The leading edge is faded at the top, I have replaced all the drums and transfer belt but the problem is still there. Has any one come across such a problem, look at the attached pic
    • 22985
    Re: Bizhub C452 leading edge faded
    ​All I see is the shadow of your arm, while taking the picture. =^..^=
    • Leyahné
      • Feb 2016
      • 44
      If you look at the left of the pic its light and on the right its solid
      • Synthohol
        Certified Konica Expert
        • 5777
        When theRe is no arrow for feed direction it's Al's just as frustrating.
        • Leyahné
          • Feb 2016
          • 44
          The area marked with the red is the leading edge, the line should be a solid black line and not grey.
          • Techlife
            • Mar 2015
            • 27
            I had this problem on a C452, but would only occur on the first page, all other pages in a print job were fine. Turned out to be firmware related
            • Leyahné
              • Feb 2016
              • 44
              Thanks will try that and revert back to you
