Biz hub c 220 Copy issue
  • raveendrala
    • Oct 2016
    • 81
    Hello
    I got couple of Biz hub c 220 machines with Copy issue (Printouts OK) .Please check attachment.
    Any help would be great.
    Thank you​
    • 23010
    Re: Biz hub c 220 Copy issue
    What have you done so far? =^..^=
    • raveendrala
      • Oct 2016
      • 81
      Print out alignment OK copy had issue both ARDF and Flatbed , I didn't try anything .
      thank you for your reply
      • mo0651
        • 1054
        When was the last time optics were cleaned and stabilization and calibration ran??
          • 23010
          #2) demonstrate that you have made some attempt to fix it. =^..^=
          • doinbox
            • Jan 2013
            • 121
            Your issue is more than likely the scanner bed has dropped because there is no support at the front left corner. Get your hands underneath the scanner bed and lift it up. It might take a few attempts. I carefully use a car jack in the workshop to resolve this. Hope this helps
            • raveendrala
              • Oct 2016
              • 81
              Thank you very much for your advice , Scanner bed lift up and problem solved.
              • rrrohan
                • Sep 2011
                • 1977
                yeah i think using a jack onsite at customer's might get you some funny looks
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4786
                  Yeah I hear you about the jack. If I showed up with a jack some of my customers would ask if I could rotate their tires while there
                  • doinbox
                    • Jan 2013
                    • 121
