FS536 Grippers out of sync.
  • cpyfixer
    • Oct 2008
    • 11
    We have a BizHub 808 with FS536 about 1.3 million on the machine. The front (operator side) gripper will get out of time with the rear one, causing severe mis-stacking and J-7221 jams. We have retimed the gripper and it will work fine for a week or so ( around 10k pages) and then get out of sync again. No obstructions that we can find, but seems like it must be hitting something. Any ideas? Photos show correct and out of sync position of grippers
    • 23006
    Re: FS536 Grippers out of sync.
    There are individual parts for the eject assy but its a PITA to disassemble/reassemble. Order the assy.
    • bizhubber
      • Nov 2016
      • 13
      I had this happen more than a couple times and eventually concluded customer was taking stapled sets off finisher tray before the job had finished. Put a conspicuous note on finisher to not take copies off tray until job is completely finished and " poof " no more mysterious out of time eject belts. . .so far (8 months)
      • Woxner
        • Jul 2011
        • 845
        i have seen this happoen when working on the machine. not just a customer error. solution is to replace the gripper as a unit. has always worked after replacment
          • 23006
          It's very similar to the eject unit on the FS534 which did this constantly. There were probably 10 bulletins worth of changes before the FS536, so I was hoping that KM had this figured out. I guess not.
          The cycle of bulletins is kind of entertaining. The first bulletin is usually a minor change or a mylar. In the second bulletin there's some more serious change. In the third bulletin, they tell you to ignore bulletins #1 and #2 because they did not fix anything, and to only follow bulletin #3. Etc, etc.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            They get one chance with me, first time i retime them if it happens again in a short time I replace the entire eject unit. FS-534. 536 and 537, done them all. Doesn't happen again after that.
