Bizhub C3350 exit roller removal
    • 8132
    Quick question please, exit rubbers have split & fallen out so paper doesnt exit very well jams or wrinkles so have ordered a new exit roller. My question is how does it come out!? No explanation in the CE manual.
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5804
    Re: Bizhub C3350 exit roller removal
    which ones? follow the clutch replacement on page g-61 in the SM to remove the exit unit. the scanner has to come off.
    btw, can you just roll electrical tape on the crappy rollers?
      • 8132
      [QUOTE=Synthohol;711300]which ones? follow the clutch replacement on page g-61 in the SM to remove the exit unit. the scanner has to come off.
      [/Q
      Item 16 rubber has gone so just need that roller out to fit a new one, I did think about using rubber tape, but they are also used to pull paper back in for duplex not sure how reliable that would be!?
      • 3ktlc
        • Feb 2018
        • 180
        Be careful taking the scanner off. Those ribbon connectors are very delicate.
