Bizhub 754e
  • Gina82
    • Oct 2017
    • 98
    Bizhub 754e
    I have a bizhub 754e giving me a jam code in cassette 4. There was paper behind the 4th paper cassette, but it was removed and all the paper was retrieved. The machine is still saying there is a jam but gives no error code and it was trouble reset multiple times but the message still appears.
    Re: Bizhub 754e
    print out the error code sheet.... it might be logged there... sounds like you might have a sensor out of place or defective.
    have you run sensor test in SM?
    Page counts on replaceable parts?
    Have you cleaned out the sensors?
    • Gina82
      • Oct 2017
      • 98
      Re: Bizhub 754e
      Which sensor would you think it might be. I have examined the paper feed unit, but I don't see anything out of place. How would I print the error code sheet on this machine?
        Re: Bizhub 754e
        RTFM
        • Gina82
          • Oct 2017
          • 98
          Re: Bizhub 754e
          Can you clarify on the abbreviation RTFM
            Re: Bizhub 754e
            READ THE FRIGGING MANUAL
            • Gina82
              • Oct 2017
              • 98
              Re: Bizhub 754e
              Very helpful.
                • 23007
                Re: Bizhub 754e
                Did you mention a jam code? I don't think so. =^..^=
                • Woxner
                  • Jul 2011
                  • 848
                  Re: Bizhub 754e
                  might have blown paper feed board. this happened on earlier series
                  • cycle66
                    • Jun 2014
                    • 13
                    Re: Bizhub 754e
                    Try checking the connector on the back of the tray, sometimes paper will get stuffed inside the connector and cause this.
                    • D_L_P
                      Self Employed
                      • Oct 2009
                      • 1196
                      Re: Bizhub 754e
                      ..The machine is still saying there is a jam but gives no error code and it was trouble reset multiple times but the message still appears.
                      I know your code is for tray 4 but check the reg roller auxiliary guide. There's a reflective mirror in the center just below the cleaning pad. It should be cleaned every call however, paper dust gets on in and it will show a jam after trouble resets and looking everywhere else.
                      • Gina82
                        • Oct 2017
                        • 98
                        Re: Bizhub 754e
                        There was no code given just a jam indication warning
                        • Gina82
                          • Oct 2017
                          • 98
                          Re: Bizhub 754e
                          I'll try that today and let you all know what result I get.
                          • Synthohol
                            Certified Konica Expert
                            • 5823
                            Re: Bizhub 754e
                            if no code given, just look in svc mode in counters.
                            • antone
                              • Oct 2014
                              • 344
                              Re: Bizhub 754e
                              Do a trouble reset..with tray 4 pulled out!
                              Sent from my SM-N950U using Tapatalk
