FS-534 jamming
  • copyman
    Owner / Technician
    • Sep 2005
    • 4591
    FS-534 jamming
    Intermittent jams. Fine when going onto top tray. From what I see on bottom tray the joggers aren't opening all the way. Strange thing is they open fine and all good when copying, they just don't open far enough (need to open about an inch more) when printing. Checked the settings for printing, first thing came to mind was it was set for a little smaller paper like Eur A4 or something. Also is fine if you select staple from print driver. Just plain printing has the issue of joggers not opening far enough.
    If I didn't see it myself I wouldn't believe it. What could be different printing and copying using the finisher.
    • 22985
    Re: FS-534 jamming
    jam code?
    FS-534 alignment plate wearing.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4591
      Re: FS-534 jamming
      Hey BC, some interesting stuff. I read a lot of it and will check it out further when I have a little more time.
      Any idea why it only does it when printing? Like I posted copying is fine from same paper drawer, etc. Also if they select stapling when printing the joggers open up all the way fine.
        • 22985
        Re: FS-534 jamming
        Anecdotally I've hear from endusers the printing is more of a problem, but from what I've seen myself, it affects anything fed to the stapling tray. Additionally, the front-to-back positioning of the paper in each tray can make a difference ... but is not any kind of a solution. =^..^=
