PC faxing issue
    • 23008
    PC faxing issue
    Ok ... this is a truly strange one. Thayer asked for my input on this one, and I was near enough to pop in. I must have made the enduser explain it to me 5 times before I got the gist of it:
    The enduser occasionally uses the PC fax driver with a bizhub C458 to transmit faxes to certain recipients. This enduser employs the built in electronic cover sheet in the fax driver to make case notes. One of these recipients complained that they could not read the case notes on the cover sheet because they were in microscopic type. All the type on the cover sheet is microscopically small. The rest of the fax transmission comes out normal sized.
    The recipient is a fax server which converts the documents to PDF email attachments. As a sample, the recipient forwarded one of these attachments back to the senders email. I got to examine the PDF document. All the pages are 8 1/2" x 11" sized (initially I had thought that maybe the first page was misrepresented as ledger then reduced, but that is not the case.) Only the type on the first page is affected. The page content properly fills a letter sized page, it's just microscopically small. All other pages remain unaffected.
    So there it is.
    The more I think of this, the more I think it's a bug in the PC fax driver. Sorry, I don't have a version #. It's the PC fax driver that generates the electronic cover sheet, yes? How is that font selected? Has anybody seen this? =^..^=
  • Synthohol
    Certified Konica Expert
    • 5836
    Re: PC faxing issue
    have they tried making another ECS? maybe the one stored is corrupt?
    if they print the ECS does it look normal?
      • 23008
      Re: PC faxing issue
      Excellent questions ... I have no answers. I'm expecting a followup call with the enduser next week. They'll be at the top of my list. =^..^=
      • NeoMatrix
        Senior Tech.
        • 3513
        Re: PC faxing issue
        Sounds like a corrupt windows font issue. A vector graphics scaling issue.
        Could the font they are using in the PC-fax software be changed to other font type, just for a test.
        Have the customer check their windows fonts directory an open each font set to see if each font set displays correctly.
        c:\windows\fonts\
        Double click each icon to open each font type.
        Is the problem with just one PC, or from all PC's with the same PC-Fax ware ?
        HTH
        • Bix
          • Apr 2018
          • 1421
          Re: PC faxing issue
          Can you print as an image?
            • 30255
            Re: PC faxing issue
            Try changing the font used
              • 23008
              Re: PC faxing issue
              c:\windows\fonts\
              HTH
              Yes, I can check the on-board fonts. I don't know what font is selected or if it can be changed without more indepth programming skills than I have.
              I do not know how many users have the fax driver, or what versions (more questions for next week).
              Do you mean to print an image of the electronic cover page? I believe that may be an option in the fax driver (another question for next week).
              Same as above: Is it selectable, and how?
              • allan
                RTFM!!
                • 5462
                Re: PC faxing issue
                Would make sense that it would be from the fax driver, or a font problem. Not something you would come across every day.
                Curious to know what the fix would be.
                Whatever
                  • 23008
                  Re: PC faxing issue
                  I don't know how pertinent it is, but this PC has very few on-board applications, and probably not many fonts either. Most of the applications are internet based. =^..^=
                    • 14755
                    Re: PC faxing issue
                    If it is only this one recipient having the problem, I would suspect it is an issue with how the fax server is reproducing the cover.
                    Have you had the customer send you a fax with the cover? If so, is it reproduced properly?
                      • 23008
                      Re: PC faxing issue
                      Another excellent question. =^..^=
                        • 23008
                        Re: PC faxing issue
                        Alright, so here's the plan. Next time onsite I will:
                        1) Print the Electronic Cover Sheet, does it look normal? If possible print-to-file, then examine the .prn file to see which font/size is selected.
                        2) Send fax with ECS to the office, how does it look?
                        3) Check PC fonts directory for font designated in 1)
                        I like having a plan. =^..^=
                        • tsbservice
                          Field tech
                          • 8019
                          Re: PC faxing issue
                          Sounds like with little help a 90% are covered Sir.
                          Good luck for other tenth.
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Re: PC faxing issue
                            Me too. I like having a plan. My plan is to win a major draw in Gold Lotto, that way I'll never have to plan again.
