Bizhub c252 problem after fuser reset
  • postmart
    • 23
    So I reset the fuser this morning with a 63ma fuse and everything seemed to go fine, reset the copier error msg went away, but not once its does a full warm up the screen just got black like its automatically going into standby mode or something. As its warming up I can go into any menu I want and pretty much do anything I want. But the moment it finishes warming up thats it screen goes black. Any thoughts?
  • Toxic
    • 698
    Re: Bizhub c252 problem after fuser reset
    When screen go black how do you recover again,restart on main switch,sub switch ?
    Did you try troublereset just in case?
    • postmart
      • 23
      Either power switch will recover to the point of it thinking its restarting. yes I did trouble reset. Im unable to copy or print by the time it warms up and stabilizes image it goes dark / standby
      • Toxic
        • 698
        In that "sleep" state,can you ping or access over web page to machine?
        If problem apear just after fuser reset i would start from there,remove fuser,check is fuse open circuit,check connectors,pinched wires...
        • postmart
          • 23
          I repulled the fuser and removed the fuse checked wires etc and reinstalled. and no i can no ping the copier
          • tsbservice
            Field tech
            • 8026
            Can you go into service mode?
            • mrwho
              Major Asshole!
              • 4299
              Found these two, apparently not related between them and not exactly your problem, but it's suspicious that they share the same cause:
              DESCRIPTION: The copier control panel blanks out when running the gradation adjustment.
              CAUSE: Poor connection.
              SOLUTION: Check the scanner interface cable for bent pins. If there are bent pins, straighten the pins with needle-nose pliers and check the female connection on the copier. Verify that the holes are the correct size and are clean.
              DESCRIPTION: 'Warming Up' message remains on the control panel.
              CAUSE: There are bent pins on the copier to scanner interface cable.
              SOLUTION: Straighten the pins on the male side and then check that the female connector holes are round shaped and not oval shaped. If the holes are oval shaped, insert a small pin to reform the hole to a round shape.
              So, check the scanner cable...
              Mascan42
              Ibid
              • Synthohol
                Certified Konica Expert
                • 5851
                fuse should be .063 1/16thA
                did you remove the fuse after it blew? did you ohm it out and make sure its open and see if it turns on?
                • postmart
                  • 23
                  No it seems to hang when trying to go into service mode
                  • postmart
                    • 23
                    Also it is allowing me to ping the copier.. for a few mins after the screen goes blank.. then it goes away
                    • Toxic
                      • 698
                      I have once similar problem with restarting,hanging up in middle of job,turning off... in no specific order,just randomly,sometimes few days without problem, so hard to troubleshot.
                      After long time finding solution problem was resolved replacing sub power switch (right side of control panel).
                      When measure with multimeter resistance fluctuate from 10 to 60 ohms and should be arround 1 ohm for proper working.
                      You have always same turning off but worth try to check this in 10 minutes.
                      • tech51
                        • 846
                        Try rebooting with the network cable out.
                        Ive had machines do this when ip conflicts occurr.
                        • postmart
                          • 23
                          Ok its has to be something with the fuser, or so I'm guessing, if I unplug the fuser, I am able to get in the service mode and the copier doesnt go dark. Im just not sure what might have happened to the fusier
                          • Synthohol
                            • 5851
                            In my last post I asked if you check the fuse once it blue to make sure that it was open why don't you cut the fuse out the test again
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4726
                              Not sure if it was mentioned but did the fuse blow and reset the life counter? Like Syn suggested remove fuse . If counter reset then fuse should be blown and not like it's even there anyway.
