Bizhub c252 problem after fuser reset
  • allan
    RTFM!!
    • 5462
    Re: Bizhub c252 problem after fuser reset
    Can remember that it needs to be a "slow blow" fuse otherwise it does not reset after blowing the fuse.
    Also think your problem could be unrelated to the fuser.
    Whatever
    • postmart
      • 23
      Yes the counter reset and the fuse did blow.. But i did remove the fuse already, I thought I said that in another reply.
      • allan
        RTFM!!
        • 5462
        What else have you tried to fix the (not the fuser) issue?
        Slow roasted and ICP or something.
        Whatever
        • copyman
          Owner / Technician
          • Sep 2005
          • 4730
          #19
          If all you did was remove fuser and change fuse, and according to your last post it will boot up with fuser unit removed then it has to be something fuser related. My guess is wrong fuse or not slo-blo like other poster said. Find a new fuser cheap on ebay, etc, replace it and be done with it. Otherwise most likely will be going back for a warped exit actuator in the near future. Very rare to get another cycle out of those fusers, mostly because of that actuator warping.
          • tech51
            • 846
            #20
            Am I missing something? Surely if you unplug the fuser you should get an error code related to it not warming up!
            Either I’m not understanding what you’re saying or your machine is severely busted.
            Either way while you’re in service mode, check for error codes.
            • Toxic
              • 698
              #21
              I agree,it should code if turn on without fuser.
              I can confirm this machines likes fast fuses,i use some time ago 100mA fast fuses, it have mark "F" (a lots of them for fuser,transfer belt...).
              postmart
              When you remove blown fuse,what you do with 2 wires,separate wires or put both wires together and isolate?
              • postmart
                • 23
                #22
                Once the wires were removed I just taped them up apart.. im sure it would fry things if I just twisted them together LOL.
                • postmart
                  • 23
                  #23
                  Ok this copier has a mind of its own, by stopping the stabilizing image by opening one of the doors to the copier, I could leave the fuser in and still get into service menu. I went and reset all counters for errors.. looked at error logs.. and pretty much checked all settings.. closed the door and by god is it working.. so toss a little salt over the shoulder and move on... Thanks for the help guys
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4730
                    #24
                    Glad you got it working. Yeah those old machines have a mind of their own.
                    I took it that you were able to remove fuser and get to a screen with error code which would allow access to serv mode, etc. Anything is better than no screen, haha
                    • Toxic
                      • 698
                      #25
                      I was hoping for some exotic and strange solution to this problem.
                      I hope you dont get same problem soon again because we all did not figure what is trouble.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4730
                        #26
                        All the great minds on this forum did come up with the solution, "fuser related". At least it sounds better then blaming bad paper
                          • 8182
                          #27
                          No where can I see you mentioned updating the firmware?
                          Always good to start any weird issue updating to the latest version so many engineers replace boards at $$$$$ cost before doing the basics!
                          • postmart
                            • 23
                            #28
                            Was able to leave the fuser in the system just had to open the door to stop the warm up.. But yea was able to reset all errors and it just started working.
                            • allan
                              RTFM!!
                              • 5462
                              #29
                              Does a soft switch count as "fuser related"?
                              Burned at the stake....
                              Whatever
