SMB ISSUE WINDOWS 7
  • qbert69
    • Mar 2013
    • 1152
    #16
    Re: SMB ISSUE WINDOWS 7
    Originally posted by mo0651
    I know!!! The Windows 10 upgrade sucked bad enough. Why did they mess with 7 ??
    Something even MORE UNSETTLING!!!
    YouTube
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Rewind!
      Somehow it works....
      • Jan 2019
      • 89
      #17
      Originally posted by qbert69
      On what brand of MFP??? Did this fix the issue with KB4480970 ???
      The security update removal was performed on systems scanning from Konica Minoltas.
      JC
      • docresources
        • Feb 2017
        • 7
        #18
        Originally posted by afterhours
        Does anyone know of a fix for the SMB scanning issues that started in the last couple days with windows 7 computers ever since the new update?
        Any info would help.
        Install the last updates and it will work. Had the same problem.
        Sent from my SAMSUNG-SM-G930A using Tapatalk
        • qbert69
          • Mar 2013
          • 1152
          #19
          UN-INSTALL KB4480970 !!![emoji6]
          • CopierNerd
            • Feb 2015
            • 207
            #20
            After update if you are getting this> "Server Connection Error" then do this> Go to Control Panel>Turn windows features ON/OFF>Telnet Client=un check, Telnet Server=uncheck, or SMB>Telnet Client/Telnet Server= uncheck
            apply and restart.
            Then try sending.
              STUPID IS AS... STUPID DOES....
              Forest Gump
              • tsbservice
                Field tech
                • 8041
                #22
                M$ released KB4487345 an update for Windows 7 SP1 and Windows Server 2008 R2.
                Microsoft Releases Windows Update KB4487345 to Fix KB4480970 Issue - Softpedia News - TECH NEWS
                • afterhours
                  • Mar 2017
                  • 152
                  #23
                  apply and restart.
                  Then try sending.
                  So I sent the original question in this thread. Removing the update definitely works, but id prefer to just make the adjustment needed for smb. Will your suggestion definitely work? I will be trying it tomorrow.
                  Im a Loser Baby!!!
                  • davel
                    • Oct 2011
                    • 1108
                    #24
                    Just try the latest update as suggested by tsbservice and see if it works.
                    • rthonpm
                      • Aug 2007
                      • 2859
                      #25
                      Originally posted by BR549
                      Here's what we did to make it work. When entering the user name, enter "//computer name/user name"
                      The issue in this month's Windows 7/Server 208 R2 patches are related to back end authentication issues.
                      You'll have issues if your scanning is set using one, or both, of the following:
                      1. Scan destination is set using an IP address instead of a host name
                      2. You're using a local account, instead of a domain account, to authenticate to the share with the account used also being an administrator on the PC or server hosting the share
                      An update has also been released to fix the underlying NTLM issue: Microsoft Update Catalog
                      Currently, it's only available from the Windows Update Catalog site, it hasn't been pushed to workstation Windows Updates or WSUS.
                      • CopierNerd
                        • Feb 2015
                        • 207
                        #26
                        No need to remove update. Just restore the changes made by update in SMB and file sharing.
                        • KMFLT3CH
                          • May 2017
                          • 242
                          #27
                          I just had this issue come up last Friday, customer called in saying her scanning to PC was not working. It's a one PC office that has been working fine for months. She was scanning fine all day Wednesday, then first thing Thursday morning it errors out with a "Forward TX Error" under job list > details.
                          I tried everything I could think of, I figured something was installed that she didn't know about, didn't think to mess with the Windows updates. I ended up just setting her PC to scan to FTP using the old FTP utility. Next time she calls in for service (probably when her IP changes and FTP stops working) I'll look for these updates and try to get her back on SMB.
                            • 14932
                            #28
                            We are done with SMB scanning. It isn't reliable enough anymore. We are switching everyone to email scanning. Once it is setup it is much easier for user to create new one-touches.
                            • KMFLT3CH
                              • May 2017
                              • 242
                              #29
                              Emphasis on "once it is set up"
                              I have far too many IT departments who haven't got a clue as to what info/settings they need to supply us in order to get scan to email working, usually those are the ones using office365 or gmail for scanning . But yes, once set up, it is the best method for scanning IMO.
                              • copyrooks
                                • Oct 2013
                                • 210
                                #30
                                Thank you guys for the updates , you guys are awesome!!!
