konica minolta -- bizhub fusers
  • n25an
    • Jul 2008
    • 1030
    I got a whole bunch of konica minolta fusers to rebuild and they have all been unboxed... some... well lets not go there... the point is... I am using the picture feature of the search engine to identify which fuser belongs to which machine... I did not see any part numbers on any of the parts... and the boxes have long since been dumped... my question... is there some kind of trick to identify these fusers... on some I see serial numbers... any help is appreciated... I got like 100 of these guys to identify...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • CopierNerd
    • Feb 2015
    • 207
    Re: konica minolta -- bizhub fusers
    There is no such thing as part number mentioned on fusing units if they are out of the box. Nope! All you have to do is to look all of them and make their categories, say those are same. take their pix and send.
    • allan
      RTFM!!
      • 5462
      If they are for the B454 B554 C454 C554 it will be tricky without a machine to fit them in.
      Had a manager order the wrong fuser 3 times in a row on those models...
      There should be like a white sticker on them?
      Whatever
        • 22997
        Pictures please. =^..^=
        • allan
          RTFM!!
          • 5462
          The 364 machines use lamps and the 554 use induction coils.
          Whatever
          • n25an
            • Jul 2008
            • 1030
            thanks for all your responses...
            when I get back to the office monday... I will see what I can do...
            I will followup...
            • n25an
              • Jul 2008
              • 1030
              I got all but two
              I took pictures of both from various angles... all images with 1 in name is of fuser 1 and images of fuser 2 have 2 in the name...
              if you guys can identify the fuser... I thank you...
              all ones...
              all twos...
              • CopierNerd
                • Feb 2015
                • 207
                Originally posted by n25an
                I got all but two
                all ones...
                [ATTACH=CONFIG]41492[/ATTACH][ATTACH=CONFIG]41493[/ATTACH][ATTACH=CONFIG]41494[/ATTACH][ATTACH=CONFIG]41495[/ATTACH]
                all twos...
                [ATTACH=CONFIG]41496[/ATTACH][ATTACH=CONFIG]41497[/ATTACH][ATTACH=CONFIG]41498[/ATTACH][ATTACH=CONFIG]41499[/ATTACH][ATTACH=CONFIG]41500[/ATTACH]
                All Images with 1 name is fusing unit of bizhub 552/652
                and the images with 2 name in JPEG is fusing unit of 658/658e, 458/458e, 558/558e, 758/758e,
                • n25an
                  • Jul 2008
                  • 1030
                  thank you...
                  • CopierNerd
                    • Feb 2015
                    • 207
                    Pleasure!
