C287 Lock Up
  • copytechman
    • Nov 2008
    • 947
    C287 Lock Up
    First off can't get into it to find the firmware version, Diag mode locks at 4 fins as does firmware download mode. If you boot normally it stays at 2 fins, I have tried disconnecting the HDD, all accessories and then some. The engine itself "runs" and if you open/close the big right door the engine cycles. I tried the MFP board with no change. Next thought is the main PSU... Thoughts anyone?
    Thanks.
    A.
  • francisco
    • Nov 2009
    • 168
    Re: C287 Lock Up
    [QUOTE=copytechman;722995]First off can't get into it to find the firmware version, Diag mode locks at 4 fins as does firmware download mode. If you boot normally it stays at 2 fins, I have tried disconnecting the HDD, all accessories and then some. The engine itself "runs" and if you open/close the big right door the engine cycles. I tried the MFP board with no change. Next thought is the main PSU... Thoughts anyone?
    Thanks.
    eMMC damaged.
    • copytechman
      • Nov 2008
      • 947
      Re: C287 Lock Up
      [QUOTE=francisco;722996]
      Thanks.
      eMMC damaged.
      OK, additional info, I've noticed that that scanner moves but doesn't light up and that the internal finisher doesn't initialize, same thing? Let me know, thx!
      • allan
        RTFM!!
        • 5462
        Re: C287 Lock Up
        Sounds like the PSU is doing fine. Never heard off this bad eMMC but i am the lucky one. Sounds like a plan.
        Disconnect every thing that does not assist in getting it to light up.
        Whatever
        • copytechman
          • Nov 2008
          • 947
          Re: C287 Lock Up
          I did exactly that, no change at all.
          Any other thoughts, and I haven't seen a bad memory board on this series yet but I guess theres always a first.
          Regards!
          • tsbservice
            Field tech
            • 8020
            Re: C287 Lock Up
            Reinstall eMMC Board, if option DIMM is installed remove and see if it boots up.
            • copytechman
              • Nov 2008
              • 947
              Re: C287 Lock Up
              Already did that as well, no change.
              Regards!
                • 23009
                Re: C287 Lock Up
                I'm pretty sure there's a Recovery Firmware for this model. IIRC the HDD firmware becomes corrupt. I've only done it once or twice. It took a couple of tries to get the process to start. Look under Special Firmware on the KM site. =^..^=
                • copytechman
                  • Nov 2008
                  • 947
                  Re: C287 Lock Up
                  I'll check that out, thanks. (The machine doesn't boot any different with or without hdd installed)
                    • 23009
                    Re: C287 Lock Up
                    That's immaterial. The software that controls the HDD can't run. =^..^=
                    • avecosat
                      • Jun 2012
                      • 305
                      Re: C287 Lock Up
                      I had to change a SSD from a c227 because it did not boot
                        Re: C287 Lock Up
                        that SSD -= IS =- the HDD in this unit... it holds the firmware info needed to boot.. so in effect you DID change the HDD. But here again this isn't the SAME MACHINE!
                        • avecosat
                          • Jun 2012
                          • 305
                            Re: C287 Lock Up
                            does that model have both SSD and HDD SSD= Solid State Device most times HDD like storage,, is there an SSD BOARD?
                              • 23009
                              Re: C287 Lock Up
                              I believe this machine has both:
                              SSD board for system software and internal data, and HDD for page data.
