C654e data overwrite
  • nathicana
    • Aug 2008
    • 329
    Re: C654e data overwrite
    Yes, that was it the life stop settings.
    service mode-stop 0 clear-IU life stop settings, set to off or disable
    • emujo2
      • Mar 2017
      • 1580
      The HDD overwrite does exactly what it's called, it overwrites all data with 1, 0, hex values and depending on what you choose (1-8) multiple times. The higher levels satisfy DOD requirements for verifying a HDD has been truly wiped. If you can retrieve data from a Bizhub that has been overwritten at level 8, you should be working for the CIA, not a copier dealer.
      • nathicana
        • Aug 2008
        • 329
        The overwrite is working smoothly but I have been unable to get the report to print out afterward.
        I log in as the administrator and enter customer's name on the overwrite report setting. "Overwrite and print report" is grayed out so I can't select it. What am I missing?
        Our salesmen like to get a data erasure report from the returned machines.
        • Albonline
          • Sep 2008
          • 1143
          #19
          Originally posted by nathicana
          I ran the overwrite on another of these machines and it says ready to copy. When I try to copy it scans the original then says ready to accept another job but won't copy.
          No codes or jams. Can cancel the job on status screen.
          Please help if you know what's going on.
          thanks
          if you (initialized all) the life stop settings will cause this.
          • B0265
            • Jan 2007
            • 718
            #20
            The report will only print from the by-pass tray.
            • nathicana
              • Aug 2008
              • 329
              #21
              Thank you
              • Synaux
                • Mar 2012
                • 1224
                #22
                Just some notes on formatting a Hard Drive (magnetic).
                For security: Physical formatting is where you must to start (low level formatting), next level is take the HDD out physically and use a computer to run a nuke program like D-BAN. Next level is to use a drill and cut holes in the plattens. Only an officious agency wouldn't accept a multi-run of something like D-Ban (imo).
                If you format the HDD you need to install the movie animation firmware (as noted).
                Unsetting the HDD in service mode will accomplish nearly nothing in terms of security.
                • tsbservice
                  Field tech
                  • 7962
                  #23
                  Complete data deletion when discarding HDD.
                  The internal data of the hard disk can be deleted by overwriting with random numbers through the settings.
                  This will prevent confidential information from leaking after the main MFP unit has been discarded.
                  [Mode 1]: Recommended by Japan Electronics and
                  Information Technology Industries Association (JEITA) /
                  Russian Standard
                  1. Overwrite with 0x00
                  [Mode 2]: US National Security Agency (NSA Standard)
                  1. Overwrite with random 1 byte numbers
                  2. Overwrite with random 1 byte numbers
                  3. Overwrite with 0x00
                  [Mode 3]: US National Computer Security Center
                  (NCSC-TG-025) / US Navy (NAVSO P-5239-26)/ US
                  Department of Defense (DoD5220.22-M)
                  2. Overwrite with 0xff
                  3. Overwrite with random 1 byte numbers
                  4. Verify
                  [Mode 4]: US Army (AR380-19)
                  2. Overwrite with 0x00
                  3. Overwrite with 0xff
                  [Mode 5]: Former US National Security Agency (NSA
                  Standard)
                  4. Overwrite with 0xff
                  [Mode 6]: North Atlantic Treaty Organization (NATO
                  Standard)
                  5. Overwrite with 0x00
                  6. Overwrite with 0xff
                  7. Overwrite with random 1 byte numbers
                  [Mode 7]: German Standard (VSITR)
                  7. Overwrite with 0xaa
                  [Mode 8]: US Air Force (AFSSI5020)
                  8. Verify
                  • B0265
                    • Jan 2007
                    • 718
                    #24
                    We have just been informed that the data overwrite will set the life stop setting back to "enable" and this will result in that no report is printed if some consumable is over life.
                    • nathicana
                      • Aug 2008
                      • 329
                      #25
                      Can someone please send me firmware for the C654e? I am having a D012 after doing the overwrite and that is supposed to fix it.
                      Do I just unzip the firmware and put the folder on a usb drive and turn on machine?
                      • nathicana
                        • Aug 2008
                        • 329
                        #26
                        Update to the d012 code after running overwrite HDD:
                        I got around the code by changing the HDD to "not set" in system 2 of service mode.
                        I'm wondering now if I should ever remove the customer's data from a Konica Minolta again.
                        It has worked nicely for me but I have had this problem twice now.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          #27
                          i always thought that the HDD was encrypted anyway.
                          • B0265
                            • Jan 2007
                            • 718
                            #28
                            Have you done the logical formatting after the overwrite?
                            • nathicana
                              • Aug 2008
                              • 329
                              #29
                              Yes, but the d012 code appeared prior to the format when I restarted the machine after the overwrite.
                              I then did the logical format in service mode but it was too late.
                              Does the logical format have to be done quickly?
                              Should I hold down the reset key while turning the machine on and go directly to service mode instead of letting the machine warm up all the way?
                              As I say the process worked a few times just letting the machine come to a stop then logical format.
                              • nathicana
                                • Aug 2008
                                • 329
                                #30
                                The company likes this report to print out as verification that the data has been deleted
