BIZHUB C554
  • DarwLeo28
    • Jun 2018
    • 10
    BIZHUB C554
    Error code c-f907
    someone has failed that failure[ATTACH=CONFIG]41559[/ATTACH]
    • 23006
    Re: BIZHUB C554
    oh, my. =^..^=
    • Woxner
      • Jul 2011
      • 845
      Re: BIZHUB C554
      try firmware first here is the bulletin
      Error
      Abort code CF907 and/or error code C6756. This may be indicated after MFP recovers from Sleep Mode.
      Root Cause
      Workaround/Fix
      PROBABLE CAUSES:
      1. Failed ErP board (PWB-DC assembly).
      Check CN2 on ERPB for proper connection. Check CN2-1 and CN2-2 for 5V DC then check CN2-3 (Power monitor in) and CN2-4 (Power monitor out). If all voltages are present, replace the ERPB (p/n A161H00C02).
      2. Possible loose connection/damaged wiring or failed board.
      To troubleshoot check the following in order, and after each step, verify that the symptom is still present.
      a. Harness connection between CCDB and SCDB
      b. Harness connection between CCDB and MFPB
      c. Harness connection between SCDB and DCPU
      d. Harness connection between SCDB and PRCBIf errors reoccur, please consider replacing the following boards in the order listed.
      • CCD board (CCDB)
      P/N MODEL
      A161R72100 C554/C454/C364/C284/C224
      A2X0R70000 C754/C654A2X0R70011 C754e/C654e/754/654/754e/654e
      A61FR72100 554e/454e/364e/284e/224e
      A5C1R70000 C554e/C454e/C364e/C284e/C224e
      • Scanner drive board (SCDB)
      P/N MODEL
      A161H01B12 C554/C454/C364/C284/C224
      A5C1H01A11 C554e/554e/C454e/454e/C364e/364e/C284e/284e/C224e/224e
      A2X0H01A12 754e/C754e/754/C754/654e/C654e/654/C654
      Note
      • DC power supply (DCPU)
      P/N MODEL
      A161R7A300 C364/C284/C224
      A61FR70000 364e/284e/224e
      A5C1R70500 C364e/C284e/C224e
      A5AYR70000 C554e/554e/C454e/454e
      A2XKR71200 C554/C454
      A2X0R70300 C754/C754e/754/754e/C654/C654e/654/654e
      • Printer Control Board (PRCB)
      P/N MODEL
      A161H00108 C364/C284/C224
      A5C1H00102 C364e/C284e/C224e
      A61FH00101 364e/284e/224e
      A4FJH00104 C454A5C0H00101 C454e
      A61EH00101 454eA2XKH00104 C554
      A5AYH00101 C554eA61DH00101 554e
      A2X0H00102 C754/C654
      A2X0H00S01 C754e/C654e
      A55VH00101 754/754e/654/654e
      • copyman
        Owner / Technician
        • Sep 2005
        • 4676
        Re: BIZHUB C554
        Might not be the issue here but I always turn off the sleep mode on the 4 series. Mostly for losing connection. You have to go into service mode first and "permit", than in admin mode turn off sleep mode.
        • DarwLeo28
          • Jun 2018
          • 10
          • copyman
            Owner / Technician
            • Sep 2005
            • 4676
            Re: BIZHUB C554
            Since you are asking I will assume you are not a tech so I cannot provide any info on how to enter service mode. Perhaps see if you can find the service manual online or you can google how to enter service mode. Beware! if not a tech you can do a lot of damage in the service mode so proceed with caution! You will also need the passwords to enter the admin & serv modes to make sleep changes.
            • rrrohan
              • Sep 2011
              • 1977
              Re: BIZHUB C554
              Yeah same. Not waking up from sleep isn't a problem if it never goes to sleep.
              • tsbservice
                Field tech
                • 8006
                Re: BIZHUB C554
                You guys mean to turn off/disable sleep mode and leave only low power mode? Or entirely leave the machine in Ready state.
                I hope not otherwise Fusers won't last longer.
                • CompyTech
                  Super Tech
                  • Feb 2011
                  • 706
                  Re: BIZHUB C554
                  This.. Those fusers will burn out quick.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4676
                    Re: BIZHUB C554
                    You can't turn off energy save mode, only sleep mode. Machines would not be able to get Energy Star certification if it was able to be turned off. It used to be 240 mins max for Energy Star now it's 60 mins.
