KM BH258 Printing problem
  • giogio80
    • May 2025
    Hello.
    Just received a brand new drum units and changed that. Transfer Belt is also changed and good, but still keeps printing stripes on the solid color. shuffling color drums but no reaction only Cyan and Black makes stripes. Please help if somebody had such experience. I think Developer unit is not so bad as well. Please help!!!
    Here are photos
  • CopierNerd
    • Feb 2015
    • 194
    Re: KM BH258 Printing problem
    You have swapped drum units but the problem is still there. So issue is not with the drum units. It is cleared.
    Now come to the second point which is Transfer belt, you have replaced transfer belt unit and it is good. when it is new it would be best. You didn't attach snapshot of transfer belt unit's life. Problem can be with black and cyan transfer rollers inside transfer belt. High voltage unit can also be the cause of this problem.
    3rd point is Developing units if you have checked them, brush OK? "K" DV unit life is expired almost, but this is not the reason.
    • Toxic
      • 694
      I would check first developing units and developing rolers for cyan and black color.
      • tsbservice
        Field tech
        • 7924
        Yep, looks like uneven pitch at 28 mm intervals. Definitely developing units.
          • 22941
          Like they said: developing units. OEM supplies? =^..^=
          • Albonline
            • Sep 2008
            • 1133
            would be looking at the drive system for those developers.
            • giogio80
              Can I buy Roller only for developer unit?? because entire developer unit is not cheap. and if yes please can anyone give me proper part numbers for that DV313C and DV313K units ???
              • CopierNerd
                • Feb 2015
                • 194
                As far as i know you cannot buy developing roller only. Its whole developing unit as you know it. There is no part number for this single part. You can take it from old developing units if you do not want to purchase new.
                • JR2ALTA
                  • Feb 2010
                  • 2028
                  If you want cheap you're in the wrong business. Or least sell Kyocera and it'll be under warranty.
                    • 14403
                    You never mentioned if you tried cleaning the printhead.
                    • 3ktlc
                      • Feb 2018
                      • 180
                      Have had a couple of dev units cause this in the past.
                      • giogio80
                        Purchased New developer unit (Black one) Changed and the same problem again. Now a bit confused ... :/
                        • Toxic
                          • 694
                          Maybe i cant see good but in first post i can see white void areas and on the last sample it looks like magenta areas on black ...?
                            • 22941
                            What interval does it repeat? =^..^=
                              Purchased New developer unit (Black one) Changed and the same problem again. Now a bit confused ... :/ [ATTACH=CONFIG]41764[/ATTACH][ATTACH=CONFIG]41764[/ATTACH]
                              looks to me the defect pattern has changed and I agree now a magenta tint.
                              did you init the dev unit properly?
