Bizhub c364e can't run stabilizer
  • Will
    • Jun 2007
    • 172
    Installed new oem K black drum unit and can not run stabilizer in gradation mode.
    Will not allow you to highlight and select paper size or copy or print modes after stabilizer is run first. Doesn't give any codes. Copies look good but can't run gradation mode to calibrate. Need suggestions.
    • 14972
    Re: Bizhub c364e can't run stabilizer
    In this situation there are usually P codes present. Check for an oil can on the display.
    • Toxic
      • 698
      Recently have same situation on C220.
      Go to service mode-Imaging Process Adjustment-stabilizer and try,not from gradation menu.
      • Will
        • Jun 2007
        • 172
        Thanks but already tried that and still no response.
        • tsbservice
          Field tech
          • 8053
          What about posting other consumables life?
          • copier tech
            • 8200
            Run the initialise + stabilise then try again.
            • dliese
              • Jan 2013
              • 2
              Make sure and have either letter or 11 x 17 in the top tray and set as normal paper. That should help you.
              • mo0651
                • 1054
                It was on this series were we had to flash the firmware before it work. Showing no P-codes or anything.
                • wjurls
                  • Feb 2017
                  • 501
                  Are the default setting set to Black and White mode? If so, select full color on the control panel before entering service mode. Then gradation should be available.
                    • 23010
                    Try running the attached document. Pay particular attention to the 11% full pages. I had a couple of machines that the magenta developer was dying. The 11% magenta was poorly developed at the rear.
                    • allan
                      RTFM!!
                      • 5462
                      If Grad/Dev AC Bias V selection is set to ON then Gradation will be disabled.
                      Setting is to enable machine to work with very dry thin air.
                      Whatever
                      • allan
                        RTFM!!
                        • 5462
                        Any Luck?
                        Whatever
                        • SAR
                          • Jul 2009
                          • 205
                          Like dliese mentioned earlier, you have to have either 8 1/2 x 11 paper loaded in the portrait direction, or 11x17 paper loaded in one of the trays (this is the paper size needed for the gradation patterns to run). If you don't, the start button will never turn blue and you will never be able to run stabilization.
                          The first time this happened to me, the customer had 8 1/2 x 11 loaded landscape direction and 8 1/2 x 14 paper in the trays and it wouldn't let me run stabilization. As soon as I switched the 8 1/2 x 11 tray to portrait the start button turned blue and I could run the adjustments.
                          • Asaadahmed003
                            • Jun 2019
                            • 25
                            Hello,
                            We had this issue a lot in the C452 i would always first check the IDC sensors to do so go to service mode>state confirmation>level history 1, and check the reading for IDC1 and IDC2 if it was lease than 1V
                            clean or replace said sensor
                            am not sure if it will help with your model but in my case it help a lot.
                            • nicaciobhz
                              • Oct 2018
                              • 5
