C654 image shift
  • Brett GS
    • Jun 2013
    • 154
    C654 image shift
    Hi all
    I got a C654 the has a image shift issue when printing on thick stock (300gsm so in spec).
    Fuser is fine, changed main drive unit (even though no P codes),transfer roller,belt is still new.Adjusted fuser speed up and down but same result.
    At first i thought it was the paper but got paper from another customer who also has a C654 and no issues.
    Next thing i am going to try is the transport/conveyance unit in the door.
    Am i missing something??
  • tsbservice
    Field tech
    • 8020
    Re: C654 image shift
    Did you try bypass separation roller adjustment, there are two positions.
    • allan
      RTFM!!
      • 5462
      So the color registration is fine?
      Is the shift consistent?
      Whatever
      • Arcadian
        • Feb 2010
        • 218
        AS ANY GOOD TECH WOULD SAY
        do you have a print sample???
        hehehe
        Clean those rollers and clean them good. Which tray are you feeding from?? The registration roller could be suspect in this case. ive seen bent out of shape entry points could be binding on one side, check those springs which holds the rollers down. one might be worn or came off. i had a few like that. they just pop right off from the shaft.
        good luck
          • 23009
          IIRC there are specific image registration adjustments based on paper source and media type. In other words you can adjust image registration differently for 300 gsm media or bypass tray, or some combination. =^..^=
          • Brett GS
            • Jun 2013
            • 154
            Update
            The conveyance/registration unit sorted issue out.
