C454 toner?
  • mrfuser
    • 1617
    C454 toner?
  • Ashbell
    • Sep 2017
    • 17
    Re: C454 toner?
    If it is a C454e than a TN-513 will fit, if it is just a straight C454 than TN-512K is the one you need.
    • kingarthur
      • 1341
      Re: C454 toner?
      TN512K will fit the C454(e) colour machine only, TN513 will fit the 454(e) mono machine only
      • copyman
        Owner / Technician
        • Sep 2005
        • 4665
        Re: C454 toner?
        Yep TN513 is for the B&W model. You sure they don't have a B&W "454e"?
        The TN512/13 have chips so not interchangeable. The same exact toner TN321 don't have chips but probably have a tab that won't allow it to fit in faster 454/554 models.
        • CraigW
          • Dec 2010
          • 417
          Re: C454 toner?
          Had a call on a mono 4 series where the bottle would not install, sent it back. Was likely the wrong black cap was installed at factory.
          • mrfuser
            • 1617
            Re: C454 toner?
            So they said cartridge says 512k/513 on it, yet won’t fit. Odd
            is the actual toner the same and just a different cap that we can swap until other toner arrives for them?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4665
              Re: C454 toner?
              Then if it has on box 512/513 then definitely an aftermarket toner and anything possible, wrong toner, defect in btl, etc.
              Really foolish to be using aftermarket in these models. It will eventually bite you in the ass. Feel fortunate it was something like this that happen. If you end up getting a bad batch of toner and it crashes your developer the units cost $500 x 3 for colors and 1 x $150 for the Black!
              • docresources
                • Feb 2017
                • 7
                Re: C454 toner?
                A C454 takes 512, a C454e takes 513.
                Sent from my SAMSUNG-SM-G930A using Tapatalk
                • kingarthur
                  • 1341
                  Re: C454 toner?
                  no it doesn't 513 is for the mono 454(e) 512 fits C454(e)
