BizHub 223 end of life?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4748
    Anyone know when or if Kon Min deemed the 223 end of life? I don't see any 223/283 on the end of life reports? Can someone email me the end of life report if they have it with the 223 on it. It came out in 2010 so think it would be in end of life status already.
  • mincopier
    • Dec 2015
    • 289
    Re: BizHub 223 end of life?
    End of life for that machine is 12/2022 according to the Konicaminolta 3 Year end of life report.
    • qbert69
      • Mar 2013
      • 1152
      We're a fairly large company & we're practically giving the 3 series machines away to small churches just to get the service revenue clicks off of them!!![emoji6]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • copyman
        Owner / Technician
        • Sep 2005
        • 4748
        Surprised to hear that if it was introduced in 2010. That will be more than 10 yrs supporting a machine! I thought it was like 8 yrs when no longer supported. They are good machines and have treated the customer and me very well
          • 23010
          They're based on the bizhub 350 which was basically bulletproof. If you put the two models side-by-each you could hardly tell the difference of the mechanical aspects.
          Only 2 months ago I did a full PM on a bizhub 350. All the parts are still available from KM. Now that shows some respect for the basic platform. =^..^=
          • JR2ALTA
            • Feb 2010
            • 2033
            EOL is a meaningless, or least misleading distinction. Parts and support will be available for years and years.
            • qbert69
              • Mar 2013
              • 1152
              Available as Long as You can get 'em!!![emoji23][emoji23][emoji23]
              • darry1322
                • Oct 2010
                • 817
                These days that includes toner hopper solenoids when I do the PM.
                Just ordered a new laser for one today.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4748
                  What are the symptoms of a bad / sticking toner solenoid? Thanks
                  • allan
                    RTFM!!
                    • 5462
                    C-2558 and ruined developer. Toner bottle and sub-hopper does not stop turning those kind of things.
                    Nothing thin weather strip like stickers can fix.
                    Its just the amount of fun removing that gearbox!
                    Whatever
                    • darry1322
                      • Oct 2010
                      • 817
                      When the noise dampening pads on the solenoid plates start going bad they get sticky. When they stick they start over toning the developer until it codes out. I clean the sticky pads off and add a two layer mylar in it's place. Like allan said, it's just a pain getting it stripped down until the hopper assembly comes out.
                      • Toxic
                        • 698
                        Today ordered 8 piece of registration roller bushings and registration clutch,they usually wear out at 500-700k.
                        I have one piece of this machine at 1.500.000 clicks and just now its showing this problem with bushings,
                        One of the rare "weak" points on this machines if it could be called weak point at so many prints
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4748
                          That's what I was thinking the sticking solenoid would cause overtoning. I just remembering when i was servicing a lot of the Biz 200/250/350 many of them would run light. Seems like we were changing drums & developers around 30-40k halfway through their life. Been awhile but might have been aftermarket drums & OEM developer.
                          • allan
                            RTFM!!
                            • 5462
                            The transfer contact on these caused light printing.
                            Always tweaked the machines to use less toner for cost saving
                            30 years for the spirit of the Di250 to die...
                            Whatever
                            • adecanmin
                              • Oct 2010
                              • 320
                              Scanning on the 350 is a challenge. Ftp is all I can use. Forget about scan to email.
