Page Pro 1490 copy black border
  • Dumus
    • Feb 2010
    • 79
    The boys ,
    I have a problem with PP 1490.
    I am RICOH boy, but this model 1490 is the same as ricoh SP 1100 (1180), and many others (XEROX, Sagem .....).
    The whole problem was created after cleaning the glass (original glass)!
    Everything is OK in the print mode (print).
    In copy mode on glass, I have a black line on the right side (copy 1), everything adjusting in normal (N) and set to A4.
    When adjusting the "flatbed margin" - (854) to the maximum,
    the line is reduced but not enough, and the diodes on the scanner are all bright.
    Have any idea, what to do?
    Print mode :
    SP 1100 PRINT.PDF
    Copy 1 :
    SP 1100 copy 1.PDF
    Copy 2 :
    SP 1100 copy 2.PDF
  • allan
    RTFM!!
    • 5462
    Re: Page Pro 1490 copy black border
    Its been ages since i last seen these machine.Sagem i believe.
    So only the general things i can think of. It the white correction patch intact and clean?
    Cant remember does this use a CIS or CCD?
    Seen better looking potato stamp prints then those samples.
    Whatever
    • Toxic
      • 697
      Lol,you are very right
      Its a CIS if i remember good.
      @Dumus
      Does black strip occur when copy from adf or just flatbed?
      Did you try scan,is it same?
        • 23007
        If that line is crossfeed, maybe you've got a break in the lamp cable? Maybe the lamp is shutting off? =^..^=
        • Dumus
          • Feb 2010
          • 79
          Did you try scan,is it same?[/QUOTE]
          Yes, black strip is in when from ADF, and in scan.
          blackcat4866 :
          All the time, the lamp lights up the whole length, and it normally goes out. Do not blink.
          • allan
            RTFM!!
            • 5462
            Its a crap little A4 SEF machine.
            Whatever
              • 23007
              Ah, thanks.
              hmmm ... so maybe you've got something blocking the primary charge, like a broken cleaner? =^..^=
              • allan
                RTFM!!
                • 5462
                Ah, thanks.
                hey not playing that. hehe
                Whatever
