bizhub C284e scan to mail issue
  • kaiser chief
    • May 2019
    • 5
  • flippinsweet
    • Oct 2013
    • 34
    Re: bizhub C284e scan to mail issue
    Are you sending as PDF? Try compact PDF to see if it makes any difference.
    • tulintron
      • Jul 2014
      • 668
      the "full disk" message appears when you choose the option to scan by email, or when you perform a scanner service?
      Which email server are you using?
      • kaiser chief
        • May 2019
        • 5
        Thanks for your reply.
        When someone tries the scan to mail function on the copier, you receive the error message on the display that the job has failed because 'server disk full'
        Our exchange server is set up as SMTP server. Nothing has changed on the exchange server.
        • kaiser chief
          • May 2019
          • 5
          Maybe a stupid question, but were can I find this option? Am looking in the menus through web connection, but cannot find it.
          • guitar9199
            • Sep 2016
            • 1100
            A couple of possibilities....
            Might be related to the administrator>printer settings>network time-out setting on the copier. By default it is set to 60 seconds.... extend this to 5 minutes (300 seconds)
            This error message also arises when Exchange cannot handle the message size or attachment size. Check the file size isn't over 10 Meg!! Most email servers throttle file size to 10 Meg, so Compact PDF might help too.
            ...or it could be the email address you're sending to is actually FULL, and they need to do some housekeeping?
            • guitar9199
              • Sep 2016
              • 1100
              YouTube
              • kaiser chief
                • May 2019
                • 5
                I changed the time-out to 5 minutes last week, didn't solve it unfortunately.
                This now happens with all scans, and it worked fine before, so I don't think it's related to file size. But like mentioned above, will try compact pdf.
                Users send scans to their own inbox, and this happens for all users, so don't think that full inbox is the issue here.
                • guitar9199
                  • Sep 2016
                  • 1100
                  Have their IT Guy check the attachment size limitations in Exchange then. It's highly likely a Micro$oft update may have changed something behind the scenes (SMB v1 anyone??), and since you said everything "worked before", this is the likely scenario.
                  • Synthohol
                    Certified Konica Expert
                    • 5847
                    also check and see if quota has been set up on Exchange because if they have reached their quota it cannot deliver that file they will have to clear out their inbox archives some things
                    • rrrohan
                      • Sep 2011
                      • 1977
                      I've always put that error back onto IT to resolve. If the server disk is full of course that's IT job.
                      • Ashbell
                        • Sep 2017
                        • 17
                        I have had this issue a few times. Most of the time it is the email address the copier uses to send out with has filled up. get the IT guys to empty the sent items folder and all should be good. This has fixed most of the machines, if no i just handball it onto IT, it does say "server" after all
                        • wjurls
                          • Feb 2017
                          • 498
                          I saw this same error once and the problem was a typo in the administrators email address. It needs to match the SMTP server account login in our case.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4718
                            Not sure if anyone mentioned this, are you sure the HDD is installed? The memory you see on display may be the ram memory which won't hold many scans.
                            • kaiser chief
                              • May 2019
                              • 5
                              This fixed it, there was indeed an error in the admin email address (.com instead of .org)
                              Strange that it worked with the wrong address for years, but thanks for all the help everyone.
