bizhub c3350 firmware update
  • mircea
    • Feb 2014
    • 70
    hello
    Any1 knows how to do the firmware update on this machine? bizuhb c3350?
    i got bothbizhubC3850Series_Cont_A3GN30G0851-899
    bizhubC3850Series_Cont_A3GN30G0851-W99
    files but im not sure about the steps i should follow. in service mode machine wont see any files on my usb stick ( zipped or not)
    Thx
  • rrrohan
    • Sep 2011
    • 1977
    Re: bizhub c3350 firmware update
    USB needs to be FAT32
    needs a folder called 'firmware' in root directory then firmware loaded into that folder as a .prn file
    start with A3GN30G0803-899.prn then A3GN30GE8C3-W51.prn then C3350_EngineA3GN0Y00050G002100.prn
    Your filenames might differ slightly but the idea is you do sub controller then main controller then engine
    Pretty sure you can only have one prn file in the folder at a time. thats how i always did it atleast
    • mircea
      • Feb 2014
      • 70
      Thank you for replying
      And is there any other special usb port besides the one on right side of touch panel?
      Thank you again!
      • rrrohan
        • Sep 2011
        • 1977
        just the front USB
        Also dont put both files on at same time start with -899 then once finished delete it off usb and put on next file
        also are you aware of the procedure to start it downloading firmware? Service Mode - Firmware Update - Select file on USB - Execute - OK
        Dont touch it until machine restarts
        • Woxner
          • Jul 2011
          • 833
          you can put all the files on the usb at one time. it should list them when you select firmware update. firmware folder needs to be all lower case
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            That's how I've always done it. Put all different firmwares for the same machine on one drive and then just choose from the list when installing. Never had an issue yet. In fact I think it says right in the book to do it that way.
            edit:
            Taken right from the book, emphasis mine.
            2.1.2
            Saving the firmware data into the USB memory device
            1. Save the firmware data in appropriate space in the PC.
            2. Connect the USB memory device to the PC.
            3. Create a "firmware" folder immediately under the drive of the USB memory device.
            4. Copy the firmware data (***.prn) in the firmware folder created in step 3.
            NOTE
            • Be sure to save the firmware data in "drive:/firmware/***.prn."
            • The printer can display up to 20 files of firmware data during upgrading.
            • The control firmware includes the following three types of file.
            Firstly upgrade the sub firmware, and then upgrade the main firmware.
            • CntUpA3GN*******-899.prn : Sub Firmware
            • CntUpA3GN*******-999.prn : Main Firmware (non-supported for Web browser)
            • CntUpA3GN*******-W99.prn : Main Firmware (Supported for Web Browser)
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • tsbservice
              Field tech
              • 7951
              Nobody want to read the books. It's all written by Japanese engineers. Just RTFM.
              • mircea
                • Feb 2014
                • 70
                Thank you . it worked.
                And i dont have the manual for those saying to read it.
                But thx for you time!
                Enjoy your weekends
                • ionutzd
                  • Jan 2022
                  • 2
                  I just found this thread, can you tell me where did you get A3GN30G0803? I'm trying to find it, it seems that's the one I need to make Airprint and Bonjour work.
                  I have 3 printers, 2 of them are working perfectly (A3GN30G0803) and one (A3GN30GM8C3) with Airprint and Bonjour disabled (and whatever I do, I can't enable them).
                  Do you have any hint, what should I look for?
                  Thank you!
                  • boot
                    • Jan 2022
                    • 3
                    Hi, I find this thread.
                    where i can get firmware updates for KM bizhub c3350? my one don't print color by wire, (as printer) with driver or with web client, only makes color copies. think i ll cure this with a firmware update or go bad in darkness
                      • 8127
                      We'd be happy to help.
                      Printer & Copier Firmware - www.printerfirmware.co.uk
                      • Synthohol
                        Certified Konica Expert
                        • Mar 2016
                        • 5777
                        or use the correct driver?
                        TCP/IP raw port 9100
                        no WSD crap ports.
                        make sure there are no restrictions on color printing in admin mode.
                        i really dont see firmware helping your PC print in color.
                        does it print monochrome at least? you only said color so i cant tell if its printing at all.
                        is color the default in the correct driver?
                        lots to check before you just hit it with firmware to fix whats likely a driver issue.
                        • boot
                          • Jan 2022
                          • 3
                          no WSD crap ports.
                          i've tried several drivers, usb and lan, try print direct through web interface. as result 4 b/w printing different density, think it were color channels by b/w. color copy good. think it mayb software bug and i need to reinstall firmware
                          • divadiow
                            • Nov 2021
                            • 9
                            anything newer than these versions?
                            Controller ROM Version A3GN30GB883-W51
                            Engine ROM Version A3GN0Y00050G001800
                            Boot ROM Version A3GN99G0100-999
                            Panel ROM Version A3GN02G0152-999
                            Scanner ROM Version A3GN23G0102-999
                              • 8127
                              C3350 C3850 C3850FS FW Read Me 8C3-W51.pdf
