Need an Image controller for Konica Minolta bizhub PRO 950
  • Balex
    • Jun 2019
    • 7
    Hi!
    I've got Konica Minolta bizhub PRO 950, but unfortunately it have no an Image controller
    I cannot find it on eBay and even can't find partnumber for it
    Does anyone know where to find/buy it?
    Thank You!
  • guitar9199
    • Sep 2016
    • 1100
    Re: Need an Image controller for Konica Minolta bizhub PRO 950
    Originally posted by Balex
    Hi!
    Thank You!
    A0Y5 H010 02 - Image Processing Board Assy
    A0Y5 H020 03 - Printer Control Board
    A0Y5 H100 01 - Controller Control Board (ICB)
    A0Y5 H120 01 - Control Board/S Assy (ICB/S)
    Not certain which one of these you're referring to, but these are the part numbers. Keep in mind that these are USA part numbers, so they might be different in your country. All but one show as available through Hytec Dealer Services ...but only as Advance Exchange. If you don't have one to send back, they're going to be more expensive.
    Good Luck.
    • Balex
      • Jun 2019
      • 7
      Thank You!
      I need a box attached behind of a main unit with ethernet and USB ports
      • guitar9199
        • Sep 2016
        • 1100
        Thank You!
        OK... a little language translation issue then. What you're looking for is called a Fiery Print Controller.
        • Albonline
          • Sep 2008
          • 1153
          no its actually part of the 950. was usually removed to get the thing through doors. list of parts tin that box.
          1 A0Y5 1331 00 Mounting Plate /C 取付板/ C D 1 a-V121 0304 03
          2 13RN 7312 0 TERMINAL PROTECTION COVER 1 端子保護カバー D 1 b-V118 0330 03
          3 26NA 7357 0 CONTACT FIXING SCREW A 接点固定ネジ A C 2
          4 40LA 7384 0 CONTACT PROTECTION COVER 接点保護カバーD 1
          5 55GA 9725 0 CONTACT PROTECT SEAL 接点保護シールD 1
          6 A0Y5 R729 00 CF ASSY C F  A S S Y A C 1
          6 A0Y5 R730 00 CF ASSY C F  A S S Y B,C,D1,D3,F2,G1,I C 1
          7 A0Y5 N196 00 Interface Cable /2 インターフェースケーブル/ 2 D 1
          8 A0Y5 1335 00 Mounting Cover /C 取付カバー/ C D 1
          9 A0Y5 H100 01 Controller Control Board ASSY コントローラ制御基板A S S Y I 1
          10 A0Y5 1337 00 Support Plate /A 支持板/ A D 1
          11 A0Y5 1320 00 Board Fixing Screw /A 基板固定ねじ/ A C 3
          12 56UA 8051 0 CONTROLLER COOLING FAN コントローラ冷却ファンB 1
          13 A0Y5 H120 01 Control Board /S ASSY 制御基板/ S  A S S Y C 1
          14 A0Y5 1332 00 Mounting Cover /C 取付蓋/ C D 1
          • copyman
            Owner / Technician
            • Sep 2005
            • 4772
            B&W models don't use Fiery PC's. The whole idea of buying the "optional" Fiery PC and why they cost $4,000+ is for the variations of colors, etc.
            Like what has been posted already the Biz Pro 950 only came with an embedded controller.
            • Balex
              • Jun 2019
              • 7
              It's not embedded, but attached to the backside
              Maybe somebody know that machine selling for parts or close to death to detach IC?
              • Synthohol
                Certified Konica Expert
                • 5898
                It's embedded. Part of the machine.
                • tulintron
                  • Jul 2014
                  • 668
                  Hi!
                  Thank You!
                  We have in stock. But we are in Brazil.
                  • Balex
                    • Jun 2019
                    • 7
                    Nice to hear it
                    How much is it?
                    What the weight of it?
                    Can you please ask the local post for the price for sending it to Moscow(Russia)?
                    • tulintron
                      • Jul 2014
                      • 668
                      Nice to hear it
                      How much is it?
                      I'll answer you by private message.
                      • guitar9199
                        • Sep 2016
                        • 1100
                        Interesting. I thought it was along the lines of the IC-414 on the C224/C284/C364/etc. series.
                        ...Learn something new every day. Thanks.
                        • tech51
                          • 846
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4772
                            I stand corrected, EFI Fiery did have B&W controllers at one time. It's been so long since they have been just color I forgot all about them.
