Bizhub c3851 prints Red/Blue when using auto color on black and white document
  • captainrva
    • Oct 2014
    • 100
    When black and white documents are printed using the auto color feature, it used to print greyscale but now this machine is printing a greyscale document with blue on the left and right with red in the middle. If you make a copy from the glass using auto color of a black n white document, it will be fine but when you print the document, this weird color effect happens. Any ideas?
  • copier tech
    • 8144
    Re: Bizhub c3851 prints Red/Blue when using auto color on black and white document
    What do the gradation test prints in CE mode look like?
    What driver are you using?
    • captainrva
      • Oct 2014
      • 100
      The gradation prints said the values were all in range and the driver is PCL 11.1.2.0. I re installed the driver and tested the post script as well.
      • qbert69
        • Mar 2013
        • 1152
        Check in the model specific driver for this machine to see if there is a sensitivity adjustment for the auto color...come to think of it, that setting might be in pagescope!!! Anyway, the sensitivity will bias it to either be more sensitive to b&w or color![emoji41][emoji1303] In Pagescope, the auto color setting should be under the print section.
        Sent from my SM-N950U1 using Tapatalk
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • Albonline
          • Sep 2008
          • 1150
          get the driver removal tool from konica website.
          • allan
            RTFM!!
            • 5462
            The document seem to be scan in color mode so its a color document. The scanner could have been wonky...
            If you manual select grey scale from the driver does it print correctly.
            Whatever
              • 23007
              Agreed. Does this affect other documents? =^..^=
              • Albonline
                • Sep 2008
                • 1150
                from what i read here there is a problem printing gray scale docs .copies are fine ,this says rip or driver. driver most likely.
                • captainrva
                  • Oct 2014
                  • 100
                  The document is a PDF sent to customer and probably was scanned from another machine using full color but when I print it to another machine using auto-color, it prints fine (black and white) but when I print to the C3851, it prints blue and red. Also, if I print in greyscale, it prints in greyscale.
