C253 Black Copies and Print Outs
  • KMNewbie
    I have a brand new C253 with about 800 copies on it and all copies or print outs come out jet black with the image in the background......KM is lost in a closet, no help what so ever, so has anyone seen this.....(PRCB, HV Board and Image Processor has been swapped with new boards per KM instruction) Also, is there any tricks to reading bias, grid voltages, etc.... on this model ?
  • ck1
    • 485
    me got one C250 also got this problem . i will try change the black IU and see. let you konw A.S.A.P
    • KMNewbie
      Tried a couple of different new drums also, still no-go......Thanks for your help !
      • B0265
        • Jan 2007
        • 718
        Try swapping the Black laser unit with one of the others.
        • copytechman
          • Nov 2008
          • 934
          I agree, try the print head swap, but also check to make sure the top of the drum/image unit is touching/connecting to the frame solidly, flaky grounds can produce a similar symtom as well.. I know you've changed an iu or 2 but also check the others for arcing @ the rear side contacts.. had it happen as well.
          Regards!
          A.
          • Benedict
            OA techy
            • Aug 2008
            • 39
            OA technician
            Hi guy
            Had a similar problem did everything under sun but after lengthy investigation found machine slightly bent on the left hand side maybe just something to take a look and look closely.
            • ni311
              • May 2008
              • 658
              You can see the voltages in the service mode.
              Is the black background on non-printable area also?
