Minolta c5500ci error code - c3300
  • kuby
    • Oct 2007
    • 1409
    Customer called and said their C5500ci has a error code of c3300. Never worked on a c5500ci. What does this error code refer to? fuser.
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: Minolta c5500ci error code - c3300
    a 5500ci is kyocera.
    • kuby
      • Oct 2007
      • 1409
      Have to call the customer. They said it was a Konica Minolta.
        • 23009
        AFAIK there is no bizhub C5500ci. This model looks like the combination of a Kyocera TASKALFA 5500i, a TASKALFA 500ci, and a bizhub C550. I think your customer is confused, and you'll need to use your own eyes to identify the model. =^..^=
        • Synthohol
          • 5847
          or google the first 7 digits of the serial number.
          thats my cheat
          • kuby
            • Oct 2007
            • 1409
            Maybe a Konica Minolta Bizhub Pro C5500?
            • kuby
              • Oct 2007
              • 1409
              WOW, customer was not close.
              Copystar CS 500ci. How do you get Konica Minolta out of Copystar?
              • Synthohol
                • 5847
                C3300 Optical system (AGC) problem
                After AGC, correct input is not obtained
                at CCD.
                Poor contact in the
                connector termi
                nals.
                Check the connection of connector YC5 on
                the ISM PWB and the connector on the
                inverter PWB, and the continuity across the
                connector terminals. Repair or replace if
                necessary.
                Defective exposure
                lamp or inverter
                PWB.
                Replace the exposure lamp or inverter
                PWB.
                Defective PWB. Replace the ISM PWB, ISC PWB or CCD
                PWB and check for correct operation.
                Code Contents Remarks
                Causes Check procedures/corrective measures
                • kuby
                  • Oct 2007
                  • 1409
                  Gotta love customers. Getting more of the story. This guy came around selling this copier and the customer I guess bought it. She said he had it in a van with the copier on ITS SIDE. What dumb a$$ puts a copier on its side. You get what you pay for.
                    • 23009
                    Hows that for guessing? Were I to guess I would say that:
                    1) your scanner is probably bent
                    2) your CCD may be bad
                    3) your scanner control board may be bad.
                    Since this machine is already obsolete, my best advice is to consider it a total loss and just dispose of it.
                    If the scanner is bent, you probably won't be able to straighten it out, or spend a week fiddling with it, and still not have it work quite right.
                    If the CCD is bad ... and you find one ... you'll still need the calibration test patterns to calibrate.
                    If the scanner control board is bad ... and you can find one ... you'll still the calibration test patterns to calibrate.
                    I really don't see how this can go well for you or for your customer. That's me: Mr. Cheery. =^..^=
