How are you? I have a Bizhub c284eShow on screen serial number must be entered contac
  • mhmds102466
    • Jul 2019
    • 74
    [Error Code] How are you? I have a Bizhub c284eShow on screen serial number must be entered contac
    serial number must be entered contact your service representaive
    I need a file firmware ​konica-c284e
  • copier tech
    • 8174
    Re: How are you? I have a Bizhub c284eShow on screen serial number must be entered co
    What work did you do prior to getting this message?
    • Synthohol
      Certified Konica Expert
      • 5849
      maybe start by entering the serial number?
      • mhmds102466
        • Jul 2019
        • 74
        [QUOTE = copier tech؛ 788843] ما العمل الذي قمت به قبل الحصول على هذه الرسالة؟
        [/اقتبس]
        NVRAM has cleared the A145FW file to clear the service manual:عيون لفة:
        • mhmds102466
          • Jul 2019
          • 74
          After entering the serial number, the code c-D010 appears again
          • Synthohol
            • 5849
            format the HDD.
            • mhmds102466
              • Jul 2019
              • 74
              how are you
              Lines are red and blue when copying only and printing is very good not showing these lines
              What do I do in lines to remove?
              Please, please?
              I can not find the serial number for my scanner because I did not put it into the system
              Enter the printer and the ADf device only
              • dave w
                • Jun 2015
                • 230
                Go through the setup process again, This is done when you power on the copier the first time from the factory
                good luck
                • Synthohol
                  • 5849
                  how are you
                  Please, please?
                  scanner serial# is on a label under the front scanner cover, remove and you will find it.
                  • Toxic
                    • 698
                    Background
                    Several reports regarding “please enter serial number” have been escalated in the Japanese and European market.
                    Symptom
                    After main power on, device starts with error message “please enter serial number “. Most of the data are cleared except consumable counters.
                    Cause
                    The Battery for the NVRAM on the MFPB is empty
                    TAEU1801592EN_After main power on all data lost_1.3.pdf
                    GHV-M1 will partially solve this problem.
                    • Woxner
                      • Jul 2011
                      • 851
                      you dont need scanner serial or adf just enter machine. in service mode when you see the key board on the right enter stop 1144 c then enter time zone leave at 00. then touch enter then touch date enter date the hit apply then end. this can happen if you also replace ssd and mfp at same time.
                      • Woxner
                        • Jul 2011
                        • 851
                        by the way if print a config page it might read generic c28 6e soft sw will need to be set
                        • mhmds102466
                          • Jul 2019
                          • 74
                          I applied the method and still
                          lines
                          When the copy is present
                          • mhmds102466
                            • Jul 2019
                            • 74
                            Is it possible for a line to appear when copying is caused by an Animation Guide Data ???
                            • allan
                              RTFM!!
                              • 5462
                              No, just follow the install guide step by step.
                              Whatever
