Bizhub 754e-654e
  • Nisar235
    • Nov 2009
    • 13
    [Misc] Bizhub 754e-654e
    nvrm reset tool plz
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Bizhub 754e-654e
    • copier tech
      • 8169
      Originally posted by Nisar235
      nvrm reset tool plz
      Hi,
      We can supply you with this firmware file(s) should you still need it.
      Feel free to drop us an email enquiry.
      Kind Regards.
      www.copierfirmware.co.uk
      • tsbservice
        Field tech
        • 8020
        Originally posted by Synthohol
        [ATTACH=CONFIG]43270[/ATTACH]
        Looks better than red card and in some cases actually may even help
        • copyman
          Owner / Technician
          • Sep 2005
          • 4718
          It would be nice that people asking for F/W make a small donation to this site.
          $5 or $10 is well worth all the advice given on this forum as well as manuals, firmware, etc
          • copier tech
            • 8169
            Exactly 👍🏻
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              nvrm reset tool plz
              If you want this tool because you can't access service mode with the CE password, -----The NV ram reset tool is for the C654 series------not the C654e series. To restore service mode access on the E series you need to generate a key. See below:
              Related Products:bizhub 224e,bizhub 284e,bizhub 364e,bizhub 454e,bizhub 554e,bizhub 654e,bizhub
              754e,bizhub C224e,bizhub C284e,bizhub C364e,bizhub C454e,bizhub C554e,bizhub C654e,bizhub C754e
              Reference
              WARNING: DO NOT use the Reset Tool on the “4e” Series. Instead, use the following reset procedure.
              1. Press the [Menu] key.
              2. Touch [Counter].
              3. Touch the following keys in this order; Stop  0  0  Stop  0  1.
              4. Touch the following keys in this order; Stop  Clear.
              5. Three items are shown below.
              Printer Serial Number
              MAC address
              CE Password Reset Request Code.
              6. Access LMS (Konica License Management System) for Administrator using a PC connected to the Internet.
              8. Click Issue Reset Code.
              9. Enter Printer Serial Number, MAC address and CE Password Reset Request Code.
              10. Click Issue.
              12. LMS issues CE Password Reset Code.
              15. Enter CE Password Reset Code on the copier screen
              16. Service mode password is now back to the default.
              • Synthohol
                • 5846
                if the OP had access to KM or LMS he would not ask for the file here.
                • blazebusiness
                  • 1257
                  True, you are right. I just didn't want him to purchase the nv ram reset tool for the non-e series from somebody and mistakenly think he could fix a CE password issue on the E series with that tool.
                  • jotunn
                    • 618
                    @blazebusiness
                    @Synthohol
                    I have a question about your LMS access level - have you got an access to "issue reset code" option as a dealers/service technician?
                    Here in EU, we've got access only iOption related buttons.
                    I saw a document for NA, about ressetting CE password which blazebusiness is relating to, so I'm curious.
                    Regards
                    • emujo2
                      • Mar 2017
                      • 1579
                      nvrm reset tool plz
                      How about some fries and a shake to go with that order???
                      • sostek
                        • May 2010
                        • 80
                        concerning access to LMS, is it necessary to be affiliated with Minolta officially or is it something which has a work-around? I have purchased 2 C754e series machines with 400k or so, but am unable to access service mode on C754e and C654e has i-option errors D272 and D012 HDD problems.
                        • Synthohol
                          • 5846
                          you can try this link but i believe you may need to sign in.
                          lemme know if it works for you openly.
                          • tsbservice
                            Field tech
                            • 8020
                            It think it won't work unless you're logged in with mykonicaminolta portal. I'm registered with LMS through EU site and this functionality is missing.
                            • Love Konica
                              • May 2014
                              • 25
                              hahaha
