General Firmware question
    • 23009
    #16
    Re: General Firmware question
    That is correct. Special firmware is the latest Basic Firmware + a repair to a specific problem. If you don't have the specific problem, use the last Basic Firmware. =^..^=
    • copier tech
      • 8176
      #17
      Originally posted by Synthohol
      Preventive maintain is one thing but since you are talking cars you wouldn't replace the tires if the tread is fine and balanced.
      I replace feed tyres before they are worn out same with my car.
      • adecanmin
        • Oct 2010
        • 318
        #18
        The base firmware is sometimes a couple of years old versus the special that is sometimes only a month old. So if you install a special firmware that fixes a particular problem: 6 months later there is a new special that fixes another particular problem. You install that one. You'll are saying the new special may remove the fix from the previous one. Does not may sense.
        • Synaux
          • Mar 2012
          • 1224
          #19
          This is how I always assumed it was organized. But due to the extreme lack of [pertinent] information from KM, I always install the latest base FW then the special (if needed). It is never stated (that I have seen) that the newer special firmware includes its predecessors' fixes--that being the newest special FW replaces the old special FW.
          I fail to understand why KM simply doesn't combine the special FWs into the base FW. This is an extremely lazy practice and creates a convoluted and often confusing ordeal for techs.
          • guitar9199
            • Sep 2016
            • 1100
            #20
            Thanks for your input. Anyway, I failed to see what it gives about my question.
            I defer to Synth on this one....
            I was just attempting to entertain.
            • tech51
              • 846
              #21
              There is an explanation. Just search for Zeus - Minerva Product FW code explanation on the Knova database if you have access to it.
              • tsbservice
                Field tech
                • 8021
                #22
                You've got your points...I have some answers to think about, now that's fine.
                It is a part of best practises(Always Outnumbered Never Outgunned) I make for myself.
                • Synaux
                  • Mar 2012
                  • 1224
                  #23
                  Hmmm, that is interesting. However, even if there is a good explanation, I doubt I will appreciate it very much.
                  I no longer have access KM's highly confidential documents, firmware, etc
                  Want to share your username and pass?
