BH C220 lost address book
  • copier tech
    • 7931
    [Misc] BH C220 lost address book
  • tsbservice
    Field tech
    • 7635
    Re: BH C220 lost address book
    I would check those settings:
    Sending Data to the Authenticated Share Folder (Scan to Authorized Folder)
    • copier tech
      • 7931
      This doesn't seem to have any relation to my issue.
      • Synthohol
        Certified Konica Expert
        • 5461
        are the names in the address book but not in the one touch?
        if you can see them in pagescope and its not just a cached page in the browser, make a backup of the address book and reimport. see if that helps.
        if not, make the backup anyway and uninstall the HDD, reboot, reinstall HDD, import data again.
        • copier tech
          • 7931
          Yes can see in pagescope not cached as used my laptop.
          Good shout will try import/export
            • 22699
            This makes the most sense to me. Especially on older machines that the addressbook has gone unchanged for a decade, I've found individual entries that read correctly on the web interface but the data is corrupt. Just deleting the affected entries and re-entering the data will make it work again. You may find that the HDD fails a format, or the addressbook data backup is still corrupt and the must be re-entered manually.
