Bizhub C652 is permanent disconnected
  • ATPAS
    • Aug 2019
    • 19
    Re: Bizhub C652 is permanent disconnected
    Originally posted by Synthohol
    please tell me you use the IP address and port 9100 and not that stupid WSD port crap? or set to LPR by mistake?
    make sure SNMP is on.
    also lock in a speed 10/100 simplex/duplex etc...
    the nic in the copier is auto negotiating and if connected to an auto negotiating hub/switch that can cause loss of connectivity as well.
    also make sure port 161 and 162 are open on the computer, those ports are how the copier tells the PC its alive.
    IP address is used, and port is 9100. RAW, and SNMP activated public and index 1. Ports was not listed in use.
    One strange thing; even if I install driver from Konica, this is the message:
    Device SWD\PRINTENUM\{BEDF9C58-5662-47C0-8BF3-80AE72DFFF2A} was configured.
    Driver Name: printqueue.inf
    Class Guid: {1ed2bbf9-11f0-4084-b21f-ad83a8e6dcdc}
    Driver Date: 06/21/2006
    Driver Version: 10.0.18362.1
    Driver Provider: Microsoft
    Driver Section: NO_DRV_LOCAL
    Driver Rank: 0x1
    Matching Device Id: PRINTENUM\LocalPrintQueue
    Outranked Drivers: oem39.inf:usbprint\konica_minoltac652_s37d5:00FF00 02 oem3.inf:usbprint\konica_minoltac652_s37d5:00FF000 2 oem39.inf:konica_minoltac652_s37d5:00FF1003 oem79.inf:konica_minoltac652_s37d5:00FF0003 oem3.inf:konica_minoltac652_s37d5:00FF1003 c_swdevice.inf:SWD\GenericRaw:00FF3001
    Device Updated: false
    Parent Device: SWD\PRINTENUM\PrintQueues
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5849
      what operating system?
      • BaconSteve
        • Apr 2019
        • 140
        • ATPAS
          • Aug 2019
          • 19
          #19
          Xerox is OK now. That was "only" an error that was not reset.
          Disable SNMP was the solution!
          It's alive!!
          Thanks!
          • tsbservice
            Field tech
            • 8020
            #20
            Although I do like your post, RAW protocol on port 9100 is the way Bizhubs should go.
            Clearly OP had things messed up after installing Xerox drivers.
            • Synthohol
              • Mar 2016
              • 5849
              #21
              100% agree unless there is a Fiery. then its LPR with Print as the queue name.
              selecting LPR on an emperon controller is just asking for callbacks.
              windows 10 auto installs printers using WSD which is a huge mistake. at least on the konicas.
              always change to IP.
