C4050i Fax button
  • kingarthur
    • 1385
    C4050i Fax button
    Got a C4050i that hasn't got a Fax button on the display, have checked the fax is installed, it came with it, all initialised, updated FW, it installed the fax FW, you get the 2 phones at the top of the screen, when you go into "Direct Input" on the scan screen, there's no button there for the Fax, and when you go into "Resolution" there's only the scan resolution, nothing for fax
    Will go back, unset & reinstall fax first, just wondering if anyone has had anything similar
    Cheers
  • Synthohol
    Certified Konica Expert
    • 5898
    Re: C4050i Fax button
    Problem
    Fax icon is missing on the operation panel.
    Solution
    CAUSE: Restrict Fax TX is set to ON.
    SOLUTION: Set Restrict Fax TX to OFF by performing the following.
    1. Select Utility
    2. Select Administrator
    3. Enter 12345678 twice
    4. Select Security
    5. Select Security Details
    6. Select Restrict Fax TX
    7. Set to OFF
      • 23010
      Also check to see that your HDD and page memory are appearing as available in the service mode. =^..^=
      • rrrohan
        • Sep 2011
        • 1977
        G00-45 onward this problem is fixed
        • kingarthur
          • 1385
          This is the FW I've installed...
