C3850fs
  • mrfuser
    • 1617
    C3850fs
  • mrfuser
    • 1617
    Re: C3850fs
    No one? Surely someone knows.
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5806
      Re: C3850fs
      Is the 2nd tray added to the driver?
      • mrfuser
        • 1617
        Re: C3850fs
        Yes it is. We have removed and reinstalled driver. Rebooted everything. Tried different versions of drivers and it still refuses to print legal.
        • rrrohan
          • Sep 2011
          • 1976
          Re: C3850fs
          what do you mean by refuse?
          it must give you a reason why it cant do it
          • mrfuser
            • 1617
            Re: C3850fs
            No errors it just prints on letter no matter what. Even if we take letter out and leave only legal it stops and says paper out and makes you put letter back in to print. We can choose legal from the driver, installed 4 different drivers, checked all paper tray settings and all correct at machine and in driver. Machine right next to it is exact same and prints perfectly fine on legal and even mixed sizes.
            Baffled
            • rrrohan
              • Sep 2011
              • 1976
              Re: C3850fs
              its not a PDF is it? Ive had Adobe Reader overwrite driver settings in the past
              • mrfuser
                • 1617
                Re: C3850fs
                Pdf, word, any doc. Same result
                • tsbservice
                  Field tech
                  • 7982
                  Re: C3850fs
                  Interesting.
                  You always can try to clear all data. There is a tool to compare soft switch settings, you can use it to check between a good one and odd one just in case of some weird setting.
                  • rrrohan
                    • Sep 2011
                    • 1976
                    Re: C3850fs
                    What tool is that, I have always just printed the management list to compare
