konica c258 ce autentication
  • lucycopy
    • Jan 2019
    • 22
    good evening to all
    I need to reset the service password in a konica minolta c258 the procedure I believe is the following
    menu ---- counter ---- print list --- display keypad
    stop-0-9-3-1-7
    nothing happens
    after the minutes that have been put, I can enter the service without a password. right procedure?
    I need the firmware to do this procedure which I think is the A7PU0Y0-F000-G00-83
    Does A7PU0Y0-F000-G00-84 still work?
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: konica c258 ce autentication
    none of that is correct at all.
    thats a recovery procedure for admin password lockout on the smaller boxes.
    also g00-84 is from 2016.
    current version is G00-W4
    • lucycopy
      • Jan 2019
      • 22
      and how do I get into service mode?
      what is the right procedure?
        maybe get the correct service manual?
        look on their tech site for UPDATES?
        • lucycopy
          • Jan 2019
          • 22
          I thought the procedure was the one I have all the manuals but I wanted to know if there was a different way to do ram initialization
          • tsbservice
            Field tech
            • 8003
            If not KM dealer you cannot reset CE password on this model there isn't reset tar file but lms.
            Ask your KM support if possible for the right procedure. Sorry, not much help.
            • Walterj
              KONICA MINOLTA
              • Jun 2017
              • 89
              good evening to all
              stop-0-9-3-1-7
              nothing happens
              good day
              Dear
              I commented that to restore the EC you can use the fw (reset tools)
              and then do the procedure you did
              If you do not recover, you must contact KM so that they generate a code to be able to reset the password to that of the bone factory 9272927292729272
              Regards
              Luck
              • lucycopy
                • Jan 2019
                • 22
                ok...
                so can you tell me the right procedure?
                o this manual is not the right one?
                http://www.oes-solutions.com/wp-content/uploads/upcp-product-file-uploads/bizhubC368_C308_C258SecurityFunctionSvcManual.pdf
                • copier tech
                  • 8138
                  good evening to all
                  stop-0-9-3-1-7
                  nothing happens
                  This procedure is only to clear the release timer after you entered the wrong CE too many times.
                  It will not reset the CE password.
                  You'll need to contact Konica or use the NVRam reset tool.
                  • lucycopy
                    • Jan 2019
                    • 22
                    NVRam reset tool does it work in series 8?
                    • arahael
                      • Mar 2013
                      • 97
                      nope as you wish
                      • copier tech
                        • 8138
                        So the only option is to call KM.
                        • lucycopy
                          • Jan 2019
                          • 22
                          Originally posted by arahael
                          nope as you wish
                          and if I wanted to completely remove the CE password?
                          • Synthohol
                            • 5814
                            stop 0 clear CE password set to off
                            • copier tech
                              • 8138
                              How about entering CE mode from the trouble reset screen you dont need to enter the password then enter enhanced security by pressing stop 0 C then turn off CE authentication.
                              Try this method be interested to see if it will work.
