Konica C364 black screen
  • Scott
    • 196
    I am a Kyocera guy and we are geared toward them, we made a acquisition of a company that was mostly Kyocera but has some Minolta's. I have this machine with a black screen, I can hear motors running but other than that I get nothing. Anybody have any where I can start???
    Thanks in advance for any help
    Scott
    • 23006
    Re: Konica C364 black screen
    Bad page memory can cause the black screen you describe. In most cases there are additional errors that you'll be able to view once you change the page memory. =^..^=
    • allan
      RTFM!!
      • 5462
      Check if the network port lights up?
      Does the start button light up?
      Whatever
      • copier tech
        • 8142
        Scott
        Worth trying to update the firmware before you start ordering parts.
        • tsbservice
          Field tech
          • 8006
          It's kinda 'shot in the dark' to attempt FW update with black(or blank) screen
          On the other hand it may actually works.
          • Walterj
            KONICA MINOLTA
            • Jun 2017
            • 89
            Scott
            Good Day
            Dear
            I hope this contribution helps
            Remains Black screen
            Power is NOT supplied
            Contact failure of Option DIMM
            MFPB Failure
            Op Panel contact failure
            1.Check the power supply
            2. When the Option DIMM is installed, disconnect it and check if the machine boots up.
            3. Check the connector between MFPB- Operation Panel
            4. Replace the MFPB
            5. Replace the Op Panel cable
            6. Replace the Op panel unit
            • copier tech
              • 8142
              Worth a try as to update the firmware you dont need to press any keys etc start key will flash orange & turn blue when complete (assuming the panel is not totally dead)
              • Scott
                • 196
                Thanks guys I will try them all and report my findings
