Bizhub C452 Outfeed Paper Jam
  • C47Sys
    • Sep 2019
    • 15
    I've got a Bizhub C452 that consistently jams at the same output point. I've attached a picture of where the paper gets stuck every time. When copying a single page just one paper gets stuck at that location, if attempting a feed test from the service menu then it'll jam up multiple pages, One right at the rollers, one at the fuser and one from the tray coming up so seems to just be backing up from getting stuck at this point. As seen in the pictures the unit was dusty, I cleaned up the area and wiped down the rollers to see if that helped but same issue. Looking for some further assistance diagnosing what I can do to fix the jam.
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: Bizhub C452 Outfeed Paper Jam
    remove the bridge unit. will it jam if no finisher attached?
      +1
      is it kicking any error/jam codes?
      • C47Sys
        • Sep 2019
        • 15
        With the finisher disconnected / removed from the unit it'll still jam in the same position. I'll check about the bridge unit
        • davel
          • Oct 2011
          • 1104
          Check the last sensor the paper passed and +1 for what jam code, basic information.
          • tsbservice
            Field tech
            • 8016
            I have seen this once on bizhub C360 when one of FS connectors wasn't plugged into machine. Always jammed at same location. Check your finisher connectors and inspect them for bend pins.
            • C47Sys
              • Sep 2019
              • 15
              There is just one connector from the finisher to the main unit, none of the pins seem to be damaged or bent.
              The error code is 72-16 with jam locations 13 and 31 Screen Shot 2019-09-30 at 11.35.58 AM.jpg
              • darry1322
                • Oct 2010
                • 817
                Curious if you removed the bridge unit or not. It will jam with the bridge unit and the finisher disconnected.
                • C47Sys
                  • Sep 2019
                  • 15
                  Problem solved I went to remove the bridge unit and did actually find a loose connector and now there is no longer a jam
                  • darry1322
                    • Oct 2010
                    • 817
                    Congrats.
                    • tsbservice
                      Field tech
                      • 8016
                      Congrats.
                      Ditto.
                      Topic starter, now you can contribute a small donation to this site for future followers.
                      • Synthohol
                        • 5824
                        Ditto.
                        his badge is right next to yours
                        • tsbservice
                          Field tech
                          • 8016
                          Ouch, that was good one.
                          You know I'm with slimslob on this topic.
                          I contribute my knowledge, my experience, good will and brotherhood.
                          Just FYI I do consider future financial contribution
                          • Synthohol
                            • 5824
                            LOL, i laugh when people trip or walk into things too.
                            hope you took that with the intended jocularity.
                            • tsbservice
                              Field tech
                              • 8016
                              Yep, took it with me into Joke of the Day thread
