Bizhub C35 Firmware Request
  • mj12
    • Sep 2015
    • 9
    Good Day,
    I am having issues getting the Bizhub C35 to send scanned emails using gmail. From what I have read, it looks like a firmware update may be the answer, eitherway, I know I am running a older version of the controller firmware.
    I am currently running:
    Bizhub C35 Current Firmware Versions:
    Boot F/W: A12199G0050000
    Controller F/W: A12130G0561505
    Engine F/W: A12150G1120000
    Panel F/W: A12120G0014805
    Scanner F/W: A12123G0040300
    Fax F/W: A12140G0012100
  • Synthohol
    Certified Konica Expert
    • 5868
    Re: Bizhub C35 Firmware Request
    ill send you a link to the latest FW on my server because you are a contributor.
    this POS machine may not be able to use gmail, there are no bulletins i can see that allow the latest security measures for gmail or office365.
    hang tight and check your PMs in a couple minutes.
    good luck and please reply back if it does indeed work.
    • mj12
      • Sep 2015
      • 9
      Just reporting back that scanning and sending through gmail is now working. I have google set to use less secure apps and the following settings on C35 web connection interface. Instead of using smtp.gmail.com, I currently replaced it with the actual IP of 74.125.20.108, I have not tried switching back to smtp.gmail.com to see if it works. I have SSL/TLS set to enabled and Port Number set to 465. SMTP Authentication set to enabled and logging in with username@domain (I would assume if your using just gmail it would be username@gmail.com) and your password. For domain name, I have my domain name set, if your using gmail, I would assume this would be gmail.com. Only other item I have set is server capacity set to 24MB as gmail only allows 25MB attachments.
      Hopefully this helps someone else out.
      • Larsje31
        • Oct 2019
        • 2
        Is it possible to receive the firmware as well.
        I have been searching for it but its quite hard to get acces to it.
        Best regards,
        Lars
        • tsbservice
          Field tech
          • 8031
          Best regards,
          Lars
          Become Contributor to this site by donating small amount of cash and sure there will be members willing to share FW.
          • Larsje31
            • Oct 2019
            • 2
            I have made my contribution :-)
            • tsbservice
              Field tech
              • 8031
              PM send.
              Thanks for contributing!
              • ice007
                • 17
                Thanks for this information, wasnt expecting anything but it worked like a charm . Great Info.
                • bok720
                  • Jul 2019
                  • 2
                  Dear, I having message of missing toner cartridge in 2 units of C35. Will upgrade firmware can help to solve this issue? this error is still there regardless i change another new toner cartridge. The machine is stop and cannot working anymore.
                  appreciate some advice. thanks
                  • Scrappy
                    • Apr 2020
                    • 1
                    Would anyone mind sharing the firmware with me as well. It would be very much appreciated. Thanks in advance.
                    • Synthohol
                      • 5868
                      PM sent,
                      thanks for contributing
                      • synstsia
                        • May 2020
                        • 2
                        PM sent,
                        Hello, I have just made a contribution to site also and was hoping someone could send me the latest firmware for C35.
                        Thank you
                        • femaster
                          • May 2011
                          • 1515
                          Thank you
                          I'll send you a PM with a link to download the firmware files. Do you know how to install the firmware on this model? It's not that same, or as easy, as the larger MFPs. I didn't look at previous messages in this thread, so don't know if it's in a previous reply or not.
                          • femaster
                            • May 2011
                            • 1515
                            Thank you
                            It's been 3 days since I sent you a link to the firmware, so I'm going to assume that you have gotten it by now. It would have been nice to have had some sort of confirmation or a Thank You so that I know you did in fact get it. I'll be pulling the firmware down from my cloud storage tomorrow so if you didn't grab it yet, you best get on it!
                            • synstsia
                              • May 2020
                              • 2
                              Firmware was received and thank you for your lightning fast response on it! It was much appreciated. No problem updating, just wish Konica had more substantive fixes- Was hoping they would have patched the TLS encryption version so I could use my secure email server instead of gmail with compromised settings.. with business class machines though, I guess they just assume people will re-lease newer models.
