Bizhub C35 Firmware Request
  • tes
    • Jun 2020
    • 2
    Re: Bizhub C35 Firmware Request
    Hello,
    i have a "new toy" with
    Controller ROM Version A12130G01403A3
    Engine ROM Version A12150G1120000
    Boot ROM Version A12199G0050000
    Panel ROM Version A12120G00207A3
    Scanner ROM Version A12123G0040200
    Fax Board ROM Version A12140G0012000
    the latest FW can help me ?
    - i have slow speed at SMB/USB/HDD scanning (it's taking too much....may too much time to make a .pdf)
    - no scan to email
    - life attention message
    i know it's another .... request but please make'it one more time
      Originally posted by tes
      Hello, i have a "new toy" with. the latest FW can help me ?
      *** what resolution are you scanning at? ... are you compressing the file? is it in COLOR?
      - no scan to email
      *** Have you setup scan to email?
      *** What is the message?
      you should really should have posted it in the proper technical forum.
      and no IMHO firmware will not fix all problems.
      do you have a service manual for this unit?
      are you a trained tech?
      • tes
        • Jun 2020
        • 2
        I apologize in advance for my introduction and for my bad english
        - (even at 150dpi it is slow) the resolution is 300dpi color and no is not "compact pdf" and the Ethernet Settings is set to 1000Base-T (Full) so there are no problems there. i know c35 have a 800mhz cpu and it's not "comparable" with bizhub C253...... still 5 minutes for 10 pages full of text with one color stamp.
        - Have you setup scan to email ?????? - yes i have (all setting are ok... SMTP server address, port number, username, password - tested on NVR(Network Video Recorder) - test ok )
        - i have the service manual for c35 unit (0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0 and i read it 19E04
        - i know the firmware will not fix all the problems like a bios flash in 2000
        - i dont know if i am a trained tech ....i guess i'm not if i have to explain my self
        next time i will try the default..."Hello, I have just made a contribution to site also and was hoping someone could send me the latest firmware for C35.
        Thank you"
        Sorry for the inconvenience.
        • tsbservice
          Field tech
          • 8013
          #19
          Thank you"
          Hey tes, don't be discouraged.
          In your case a Contributor's badge will be big Yes for members including me to help you. But here we usually have a tons of user's requests for FW without any explanation so Phil(aka Dentist) have to pull some info from the wannabes.
          Sure you will get what you want.
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5824
            #20
            Thank you"
            sent you a PM
              Yeah I usually post as the Dentist in situations such as this.
              • tsbservice
                Field tech
                • 8013
                #22
                Thanks for that as we have no mods right now. Your efforts in this manner are greatly appreciated here.
                • gerryroehr
                  #23
                  • MArcio mss
                    • Nov 2020
                    • 2
                    #24
                    obrigado
                      Originally posted by MArcio mss
                      obrigado
                      how about you post in your NATIVE language AND IN ENGLISH ?
                      and CONTRIBUTORS always get faster service.
                      https://www.copytechnet.com/forums/v....php?do=donate
                      and please review the forum rules:
                      https://www.copytechnet.com/forums/misc.php?do=vsarules
                        Contributors get faster service: a small $10 contribution
                        forum rules here:
                        or you can
                        pay way more than that for the files you need.
                        • Remus2k
                          • Jan 2021
                          • 6
                          #27
                          Hello,
                          I'm the new owner of an old C35 bizhub.
                          I have this software version:
                          Engine ROM Version A12150G1110000
                          I understand that I need to make a contribution, but I want to know if I have an old firmware or not (older than the one present on this forum).
                          Thank you
                          • Remus2k
                            • Jan 2021
                            • 6
                            #28
                            Please send me the firmware and upgrade info.
                            I'm getting nuts with Scan to Email.
                            Gmail works, but my internal server do not work, but setting are correct and verified with an email client.
                            FW update I hope to be the fix.
                            Is there anyway to check exactly what auth error the printer has with my hosted SMTP server?
                            • Remus2k
                              • Jan 2021
                              • 6
                              #29
                              Thank you @Synthohol for providing the firmware update files for Controller, Engine and Scanner
                              Code:
                              A12130G0 - 1403A3 old
                              A12130G0 - 113779 new ????
                              Engine ROM Version
                              A12150G1110000 old
                              A12150G1120000 new
                              Scanner ROM Version
                              A12123G0040200 old
                              A12123G0040300 new
                              I have some doubts that my Controller firware was newer (?)
                              A reset to defaults fixed Gmail SMTP !
                                • 8144
                                #30
                                Happy to help drop us an email
                                www.copierfirmware.co.uk
