C458 with FK-514
  • kenpio
    • Dec 2015
    • 202
    [Misc] C458 with FK-514
    Hello,
    Have a customer that has the above mentioned machine. The customer is a medical equipment provider. They have to fax large documents, up to 140 pages! Right now the most they can get through is about 40 pages and the machine disconnects and they cannot get any more through. Right now the machine has G00-G3 controller firmware. I will attach fax report. I will update firmware, I did not see anything in the firmware newer than this one, but that is always the thing to do.
    KENWHEELS.pdf
  • tsbservice
    Field tech
    • 8053
    Re: C458 with FK-514
    It won't hurt to do newer FW as your is quite old, but I also doubt if that may help.
    What're errors in transmition report? Also you may try to initialize fax board.
    • Woxner
      • Jul 2011
      • 853
      doing as last post is one thing. sometimes reformatting the hdd is another. you can also try a fax file format under fax tab. i have customers doing same or more pages with no problem. if you do hdd back it up first
      • rrrohan
        • Sep 2011
        • 1977
        I had a lawyer who use to send huge fax jobs and complained it was failing.
        turns out the recipient was cancelling it on their end so they could send a urgent fax themselves as often it would take 30 mins for these big fax jobs to finish sending
        • Max
          • Oct 2011
          • 566
          I seam to remember there was an issue with a fax when they 1st came out. Firmware fixed it. Also try EU in fax option and not GB. Sometimes works. Turn off ECM on send if available, as it can drop the line if too many errors.
          Recommend them to join 21 century and use scan to email.
          • Synthohol
            Certified Konica Expert
            • 5892
            scan it to PC then use PCfax driver to send.
            for whatever reason it worked at the acct i tried it at.
            when faxed through the feeder it would bail out halfway through sending.
            it may be a fluke but it's worth a try.
            • Bix
              • Apr 2018
              • 1421
              Hi, make sure you have the correct market set up. For Europe it is EU.
              You could try to reduce the speed TX and disable ECM.
              • kenpio
                • Dec 2015
                • 202
                Thanks for the feedback. Went back to customer and turned the ECM off and updated the firmware to the latest and greatest! G00-W5. We will see what happens here. I guess the reason they have to fax is the HIPPA laws. The old fashion is the most private. If this does not work I told them that we would try to figure out the fax from PC thing.
                KEN
                • emujo2
                  • Mar 2017
                  • 1579
                  RightFax and other softwares like this are HIPPA compliant...we have many customers using this in Hosptals. Once you can show them that the savings (cost of each copper fax line, outpages on devices, speed--no more busy/redial, cost of fax boards) is there, many will switch over..Not cost effective with 5-10 devices, but once you get into 40, 50 and higher, the savings pay for the original outlay. E
                  • Synthohol
                    • 5892
                    if you put W5 on it did you change bit sw 25 to b0?
                    hope so.
                    • kenpio
                      • Dec 2015
                      • 202
                      No I did not... Is this important?
                      • tsbservice
                        Field tech
                        • 8053
                        Yes it is. You're asking for weird troubles if not.
                        • Synthohol
                          • 5892
                          Every firmware has an accompanying reade file that has instructions for install.
                          • tsbservice
                            Field tech
                            • 8053
                            This SW25 thing may be confused as many other models didn't have it when it comes to FW update.
                            Still I would not dare to do FW update of any make/model without reading doc/pdf coming with FW file/s.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              why would you get weird problems if you dont use function 4.2
                              thats just the highest function level it supports. ive never had dramas using 4.1 instead of 4.2
