C458 with FK-514
  • tsbservice
    Field tech
    • 8053
    #16
    Re: C458 with FK-514
    Just the fact that someone get lucky is NOT a part of my practices.
    I prefer to stick to setting right HEX Assignment in SW25, it takes like 30 seconds.
    • emujo2
      • Mar 2017
      • 1579
      #17
      You can have a MFP at W5 and the function version as far back as you want (with the exception of firmware releases that include a mandentory function change)..The new firmware addresses problems while the function verison add new features and can also remove some items. E
      • kenpio
        • Dec 2015
        • 202
        #18
        Yes I found it in the firmware pdf, it is just way at the bottom. I will pay more attention to this in other firmware updates. I will go to the customer and change this. I am happy that this customer is not 2 hours away and it is a couple miles down the street.
        KEN
        • kenpio
          • Dec 2015
          • 202
          #19
          So I went to the customer and switched 25 to B0. Before I did this the customer said that it was printing slow. Would this help that? You were talking of weird problems. They did print after I did this and it seemed okay to me.
          KEN
          • Synthohol
            Certified Konica Expert
            • 5894
            #20
            it definitely didnt hurt anything.
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              #21
              KEN
              Did you power off the main power switch after changing SW25 to B0? If not, the new changes afforded by that setting will not be realized. Also, the Pagescope web interface won't work properly until you power cycle the machine after changing SW25.
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
