Minolta C454e duplex jamming on first copy
  • copyman49
    • Sep 2019
    • 2
    I have a minolta c454e that jams only on the first print or copy after machine has sat for a few minutes or has been off for a few minutes. It only does it when duplexing. I have replaced the exit solenoid and recently replaced the whole exit unit. Thanks.
  • Bix
    • Apr 2018
    • 1421
    Re: Minolta C454e duplex jamming on first copy
    Hi,
    maybe in this:
    The two ends of the Switch Gate are touching black cushions which are attached on the right side door. The fuser sometimes makes them sticky when they cool down.
    You should try not to make it sticky, for example by attaching a piece of P/H window Cleaning Pad or something similar
      • 23010
      Jam code?
      • kmcopiertech
        • Dec 2019
        • 2
        Didn't know if this got resolved or not yet, but here is a bulletin that we have found works for a similar issue. Hope this helps
        11198.pdf
        • copier tech
          • 8202
          Originally posted by Bix
          Hi,
          maybe in this:
          [ATTACH=CONFIG]43836[/ATTACH]
          You can simply peel them off.
